Model T Emoji for my cell phone?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Fri May 03, 2024 4:12 pm
I was asked why I don't have a Model T Emoji for my cell phone? Good question. I looked for one and could not find one. Does it exist for iPhone?
ModelTWoods
First Name: Terry
Last Name: Woods
Re: Model T Emoji for my cell phone?
Post by ModelTWoods » Fri May 03, 2024 5:36 pm
Ignacio, take a picture of your T or your favorite T photo and transfer it to your phone's wallpaper.
signsup
Last Name: Brough
Post by signsup » Sat May 04, 2024 10:04 am
If you have a unique horn, you can also record it and use that as your ring tone. I have a WWII jeep "beep/beep" as mine and a lot of people recognize it.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sat May 04, 2024 11:20 pm
So no model T emoji exists? These are the little ones you put in a text message: :D :oops: :evil: :? 8-) :ugeek: :mrgreen: :arrow: :?: :!:
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Sat May 04, 2024 11:35 pm
Oh, so that is what you were looking for ! I don't think the EMOJI Gods have had a call for that one yet. Unless you can sign up a list of T owners who are as eager to express their feelings with such vigor, you may be in for a wait for such a symbol. :D
joe.wal
First Name: Joerg
Last Name: Walther
Board Member Since: 2014
Post by joe.wal » Sun May 05, 2024 8:13 am
No idea if it can be used on the apple thing ...
1916 Touring
PDGx
First Name: Paul
Last Name: Grohsmeyer
* REQUIRED* Type and Year of Model Ts owned: ‘17 TT Holmes Wrecker
Post by PDGx » Sun May 05, 2024 9:51 am
Well there is a way to get that done depending on what phone or iPad you have.
Bring up a photo that has not been edited (doesn’t work well if edited) and hold your thumb/finger on your vehicle. If the screen appears to ‘cut out’ the image with a white line, you are in.
You will be given the option on the pop up to ‘copy - add sticker - or share’
Select ‘add sticker’.. You will see it added to your emoji file
You can then use it like an emoji in text messages - but this site……doesn't let you use it.
Try it. It might work on your hardware.
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor / 85 Roger’s RGN
08 Philbilt Stepdeck Semi
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun May 05, 2024 12:36 pm
So far the answer is: with difficulty. I created this little .png attached but to get it to display correctly as an emoji on iphone is far more difficult than it should be. If you copy it into a message it scales it up beyond actual size which makes it look blurry. At this point I cannot find a way for it to display actual size. So far there is no easy way that I can find to put it on as an emoji. :( -- IV
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun May 05, 2024 12:41 pm
I hold down on it, it outlines but then it only brings up Copy and Share... no Add Sticker. :(
PDGx
First Name: Paul
Post by PDGx » Sun May 05, 2024 1:33 pm
Suggest you check your iOS version. My 16. iPad doesn’t work, my 17. does. ??
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Sun May 05, 2024 9:06 pm
I updated to the latest and now I hold down on it and it does nothing. :o
