Rebuilt universal joint question
Reno Speedster
First Name: Morgan
Last Name: Blanchard
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T Speedster Project, 1922 Runabout Pickup
Post by Reno Speedster » Fri May 10, 2024 10:27 pm
I am in the midst of building the rear and for my speedster. I got out the rebuilt u joint I had on the shelf. It’s a Golding t parts one I bought years ago. There is a sticker on it saying that it being stiff is normal and it will get better with use. It is pretty stiff. Has anyone got experience with these? Should I look for a different one?
Re: Rebuilt universal joint question
Post by Jerry VanOoteghem » Sat May 11, 2024 7:11 am
I wouldn't use it in my car. The needle bearings are riding on the relatively soft pins of the u-joint yokes. As the tag states, it will loosen up... and never stop. I saw the result of using a similar unit in a friend's T. Too much material was removed from the outer ring in order to fit the needle bearings. The ring broke and destroyed the ball on the end of the torque tube. That u-joint at least had hardened sleeves fitted to the pins.
Reno Speedster
First Name: Morgan
Post by Reno Speedster » Sat May 11, 2024 11:23 am
Thanks Jerry, this did not seem like a good idea. Properly fitted roller bearings should be friction free and if they “wear in” something is not right. I got this with a bunch of parts from a friend. I will dig and see if I have a good u-joint and if I don’t, I will buy a new one.
Post by speedytinc » Sat May 11, 2024 11:46 am
Too bad. I always wanted to try one. Thanks for the heads up.
Another re-engineered part that falls short of OEM longevity.
