correct 25 touring rear window
NY John T
Last Name: Killelea
Post by NY John T » Mon May 13, 2024 1:47 pm
Hi all,
Just wondering what would be the correct rear window for a Dec. 24 Touring. A two panel or a one panel. Does anybody know when Ford switched from the two panel to the one panel?
Thanks,
John
Last Name: House
Re: correct 25 touring rear window
Post by George House » Mon May 13, 2024 2:16 pm
I’m gonna jump out on a limb and say the 2 lite style due to the verbiage in this ad: Bottom ad for Peer O Lites “and in 2 lite style for 1923 and later.” Of course we know the long horizontal 1 lite style was used for ‘New and Improved’ 😀
NY John T
Last Name: Killelea
Post by NY John T » Mon May 13, 2024 3:55 pm
I'm just wondering about several 25's with the single window. Also I saw a vintage ad with a single. Anyone know the changeover date?
Post by Jerry VanOoteghem » Mon May 13, 2024 4:09 pm
I'm pretty certain 1925 had 2 rear windows. Period ads to the contrary were most likely for aftermarket versions. For instance, my '25 Touring has one window. It's a glass window in an aftermarket metal frame and not correct.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Mon May 13, 2024 5:48 pm
According to the encyclopedia, the late 1925 had the single rear window.
Post by Jerry VanOoteghem » Mon May 13, 2024 8:35 pm
Interesting. My Touring is a late '25, so maybe it's legit.
First Name: Austin
Last Name: Farmer
Post by 1925 Touring » Tue May 14, 2024 1:12 pm
Our 25 touring has a single square window in back. Im not sure if that's the original style or not. It was built to be a driver.
Last Name: House
Post by George House » Tue May 14, 2024 1:54 pm
I think Henry Ford announced component changes thru printed ‘Ascessions’. The OP listed his touring as a December ‘24 so that would, indeed, make it a ‘25 model. Austin, is your ‘25 rear window of the isinglass or metal frame with glass variety like Jerry’s ? What we really need is a Forum Friend up there in Dearborn to find that printed change in the archives to answer the original question.
Post by Jerry VanOoteghem » Tue May 14, 2024 2:46 pm
I believe the archives are still closed to the public.
Derek Kiefer
First Name: Derek
Last Name: Kiefer
* REQUIRED* Type and Year of Model Ts owned: 1925 Touring, 1926 Gow Job
Board Member Since: 2011
Post by Derek Kiefer » Tue May 14, 2024 3:47 pm
I have tried to find the same information. The encyclopedia says single window for "later 1925" but no approximate estimation on when the change occurred. Is "later" the last half of the year, or the last month?
I assume mine should be single window with its May 25th 1925 engine assembly date.
NY John T
Last Name: Killelea
Post by NY John T » Wed May 15, 2024 1:30 pm
I've been on the fence about this question. My engine is a December 24 date. So definitely not a late 25. It's 4 months in to the 25 model year; and 8 months away from the end of the 25 model year. So I think I'll go with the two windows. Anyone know of a reason NOT to go this way? Thanks. I think I saw la 1925 Ford ad showing a single rear window, but I think it might have been for the late 25. Who knows?
Last Name: House
Post by George House » Wed May 15, 2024 8:04 pm
I think you’re correct in your assessment John. Indeed, I believe the single isinglass window was introduced in 1925 well within the 1926 program year.
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring(2), 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Wed May 15, 2024 9:03 pm
I restored a July 1, 1925 Touring over the last few years and did a fair amount of research on 1925 cars to try to keep my car original. I never came across a specific start date for the 1925 single rear window but did read about many changes that happened during that April into July 1925 time frame.
I also found Larry Smiths' article on the 1925 Pickup very helpful as he outlines a lot of the changes that happened in late 1925 during the release of the 1925 pickup. In that article Larry comments about the single larger window probably better accommodated the new rear view mirror.
An interesting change I found in the 1925 Documentation Section of the Encyclopedia was that on April 6, 1925 the New York Branch announced that they were prepared to supply Nickel plated radiator shells, nickel radiator aprons and nickel head lamp doors for 1925 cars through their service stock.
Imho, I would be comfortable calling an April to the end of July a late 1925 car for the purpose of having a single rear window.
NY John T
Last Name: Killelea
Post by NY John T » Thu May 16, 2024 10:16 am
Thanks for all who commented. This is a great club with many helpful people contributing. I appreciate it.
John
Post by Original Smith » Thu May 16, 2024 3:05 pm
Single window. All you need to do is look at original 1925 photos!
Last Name: House
Post by George House » Thu May 16, 2024 6:33 pm
Ever seen an original ‘15 wide track with 2 rear ‘lites’?
