Copper intake/exhaust rings
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Fri May 17, 2024 1:12 pm
Are the crushable copper intake/exhaust rings reusable? I’m thinking not, but I’d like to be certain.
Last Name: House
Re: Copper intake/exhaust rings
Post by George House » Fri May 17, 2024 1:32 pm
I wouldn’t - once they’ve lost the designed utility of being crushed by manifolds…. I do reuse cotter keys tho’
Post by Jerry VanOoteghem » Fri May 17, 2024 2:10 pm
Not reuseable.
Last Name: Patrick
Post by jiminbartow » Fri May 17, 2024 2:33 pm
No. They are designed to assume the irregularities (such as rust pits) of the surface they are pressed into. If they are rotated or transferred to a different port, the surface changes and they can no longer seal properly.
Belliott3
First Name: Bill
Last Name: Elliott
Post by Belliott3 » Fri May 17, 2024 2:51 pm
Thanks for the confirmation: I thought they were one and done!
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri May 17, 2024 3:10 pm
I have reused them when I’ve had do repairs on a road trip. The important thing is to retorque them HOT on reassembly and possibly more than once
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Post by Ed Baudoux » Fri May 17, 2024 7:58 pm
If they're not seriously deformed, anneal them by stringing them on a piece of wire, hearing them red with a torch, and quenching them in water. They'll be soft enough for reuse.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Post by Steve Jelf » Fri May 17, 2024 11:11 pm
It may be overkill, but I smear some hi-temp RTV on them, especially if the engine surface has any pitting.
