Correct oil for Muncie transmission
Topic author - Posts: 597
- First Name: Morgan
- Last Name: Blanchard
What oil should I be using in my Muncie auxiliary transmission?
- First Name: Dennis
- Last Name: Prince
Re: Correct oil for Muncie transmission
I use 140w gl-4, not sure if that is what it calls for but it has worked well for many years.
- First Name: craig
- Last Name: leach
I run 85-140 & Ed AKA #4 the 600W Ed has way more miles than I ever will.
Craig.
Craig.
- First Name: DAN
- Last Name: MCEACHERN
Redline Oil makes a synthetic heavy duty gear lube called Shock Proof. It has worked extremely well in my Chicago transmission. It runs cooler and is much quieter since I changed it over from conventional gear oil.
