Yale Running Board Toolbox
1923Touring
First Name: Joshua
Last Name: Hawkins
Post by 1923Touring » Wed May 29, 2024 4:08 pm
Does anyone have a Yale running board toolbox that looks similar to this? I am trying to determine if the top of the lid is supposed to be flat, or have a bow or crown in the outward direction. Mine is dented, and I want to make it right.
Thank you,
Joshua
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
Re: Yale Running Board Toolbox
Post by Jack Putnam, in Ohio » Wed May 29, 2024 4:11 pm
Flat! At least mine is.
1923Touring
First Name: Joshua
Last Name: Hawkins
Post by 1923Touring » Wed May 29, 2024 4:33 pm
Thanks Jack. I am interested to see what others say too. I just took pictures of the lid, and the "crown" on mine does not look symmetric.
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Wed May 29, 2024 5:19 pm
Mine is flat also. No crown.
Post by Allan » Wed May 29, 2024 5:52 pm
So is mine flat also. Yale may only be the latch/lock maker. The box maker could be any manufacturer.
KBurket
First Name: K
Last Name: Burket
* REQUIRED* Type and Year of Model Ts owned: 1926 RPU
Post by KBurket » Wed May 29, 2024 7:30 pm
Slight crown even though this box has been sat on, stepped on, and had stuff piled on top in storage.
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Post by michaelb2296 » Wed May 29, 2024 9:04 pm
Flat on top! Maybe a Globe Toolbox ? with Yale lock! Do you know the key #????
I’m missing my key! But i know its a flat yale key.
It’s out being sandblasted as i post a reply!
Post by Wayne Sheldon » Thu May 30, 2024 6:02 am
A lot of companies made similar boxes with the raised area on the lid. I have seen many of them, some very flat, some with a slight hump. One could be restored either way (if damaged enough to not be able to tell?), and basically nobody would know the difference.
Peerless made thousands of similar boxes. Ames was an early maker of whole speedster bodies, kits, and pieces, including seats and tool boxes sold individually. A dozen other sheet metal companies made similar tool boxes. Most did not have the manufacturer's name on them in a manner that would survive more than a few years. Peerless used small decals with their name on them (I don't recall who, but someone reproduced these decals a few years ago from a nearly NOS original box!). Years ago, I saw one with the remains of a paper label inside the tool box (the name of the manufacturer was mostly gone!). Decal or paper, the labels usually were gone after only a few years.
Yale locks were used by many manufacturers, as were a few others. And many tool boxes didn't have a lock, just simple latches.
modeltspaz
Last Name: Spaziano
Post by modeltspaz » Thu May 30, 2024 10:22 am
The late Larry Sidmore (the guy that used to sell the reproduction small drum A C brakes) used to sell reproduction Globe tool box decals at the Bakersfield swap meet.
Since his passing, I have no idea what happened to them.
Mike.
Post by Jerry VanOoteghem » Thu May 30, 2024 2:00 pm
There were most likely dozens of companies that made these. To say that yours is wrong because it's crowned wouldn't be fair. Besides, even if you did want to make it flat, it would be nearly impossible to get it dead flat. Go with the crown. It looks nice. It'll shed rain better that way :)
Post by DanTreace » Thu May 30, 2024 5:10 pm
My box is flat on top, rather think they all were mostly flat. Many makers, and the size for the Ford should be 9" width, so the box won't hang off the running board edge.
Now for those long lost tool box latch keys.......well just add a hasp and your own lock. Or just a whittled wood stick to jam in the latch to keep it closed :lol:
1923Touring
First Name: Joshua
Last Name: Hawkins
Post by 1923Touring » Thu May 30, 2024 6:30 pm
Michael, I do not have a key, and I have not seen a key numbers stamped onto the lock. I would presume there either is no number, or it is buried under the old paint.
Post by DanTreace » Thu May 30, 2024 8:37 pm
These pics were on the forum a while back, shows the key style of a Yale lock for tool boxes, rather generic looking and simple. They are all the same.
The other pic is one that was homemade to fit the Yale lock and make it open and close.
Image 4-30-24 at 9.05 AM.jpeg (33.12 KiB) Viewed 3173 times
Image 4-30-24 at 9.10 AM.jpeg (30.62 KiB) Viewed 3173 times
Tried to make a similar key for my running board battery box with lock, but the lock tang had been busted out, so no way to lock, at least the latch holds it closed.
Post by Steve Jelf » Thu May 30, 2024 9:16 pm
Did Ford ever sell tool boxes? My 8-5-28 parts book lists a tool roll but not a box. I have always thought running board toolboxes were made by other companies, not Ford, as an aftermarket accessory. Is that wrong? Does any Ford parts book show a toolbox?
Post by RajoRacer » Thu May 30, 2024 10:00 pm
Only Ford supplied tool box I've seen was on the back of a Torpedo ! Nice to see you commenting again, my friend !
Post by Allan » Fri May 31, 2024 3:07 am
It may well be that the slight crown in the lids is due to the way the lids are pressed. All that compound curving on the corners and in the raised top section is likely to leave stresses in the metalwork which cause the crown.
signsup
Last Name: Brough
Post by signsup » Fri May 31, 2024 11:49 am
Do not know what is OEM, but I presume anything that might be exposed to rain would benefit from a slight crown to facilitate run off. I wondered why the running boards did not have a weep hol or two in them, but perhaps the front to rear pitch to them provided enough drainage. Maybe my supports are worn, but my running boards have a rear ward tilt to them. Maybe a flat toolbox mounted on that same running board would also have the same rear ward pitch to it.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
Mark Nunn
Last Name: Nunn
Post by Mark Nunn » Fri May 31, 2024 12:52 pm
My box has a Perfection Lift Lock. Clasp. The box has a flat top. It also has a seperate compartment in the back. The shape is perfect to fit a Ford tire pump. I have never seen another with the separate compartment.
Post by John kuehn » Fri May 31, 2024 1:41 pm
The tool box I had but later sold was a nice near mint box. The top wasn’t flat but had a very slight crown. It had very nice paint and patina and you could just see the slight crown and each corner to crown X that was pressed into the top when it was made. My thought is that it was that way to keep it from collecting water on the top. I never thought about until the question was asked here. I haven’t kept up with tool box posts and pictures of them but the box I had has a very slight crown. I think Allan’s post has a good explanation about the crown.
