26 fordor part where does it go
Tinner12
Topic author - Posts: 147
- First Name: Vernon
- Last Name: Enis
- * REQUIRED* Type and Year of Model Ts owned: 1917 and 1924 touring,1926 4 door
- Board Member Since: 2011
I took these two parts off of the rear windows and I can't remember where they go. One for each side? Car is coming along good. Just painted the body. Still have the fenders and hood to paint. You have to lay down to look at the one picture!!!!!
- Attachments
- IMG_0705.jpg (36.68 KiB) Viewed 1922 times
- IMG_0704.jpg (25.4 KiB) Viewed 1922 times
Tinner12
- Last Name: Enis
Re: 26 fordor part where does it go
move to top
Moxie26
- Last Name: Jablonski
Got dizzy
- Attachments
- IMG_0705~2.jpg (26.8 KiB) Viewed 1749 times
Joe Bell
- First Name: Joe
- Last Name: Bell
inside the rear qtr windows for the felt strip guides, the steel doors should have guides in them but rear has wood and they tack in place.
bnchief
- First Name: Steven
- Last Name: White
exactly what joe said i just finished a fordor snyder has the right felt door channel also just not like original and you will have to do some shaping
Tinner12
- Last Name: Enis
OK. Thanks very much. I put all new channels in so I coverd up the old nail holes. I knew they went there some where.
Tinner12
- Last Name: Enis
Well I thought I knew where the parts go but I can't find any old holes for them. Could someone give me a drawing. Thank you
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
They should go under the rear quarter belt rail where the window assembly goes. The original felt window channel sits in them.
William L Vanderburg
1922 Center Door Sedan
