Rear axle question
Topic author - Posts: 2967
- Last Name: Hjortnaes
Rear axle question
If you are installing the old axle seal you will use the steel washer outbound of the hyatt bearing.
If you are using the modern axle seal with o rings, do you still install the steel washer?
JohnH
- Last Name: Hunter
- Board Member Since: 2002
Re: Rear axle question
No, the steel washer is not used. It keeps the bearing and felt in position for the original type seal. The modern seal keeps the bearing in position by itself.
