Anyone used this type of hood?
skyhunter
First Name: Donncha
Last Name: OapostropheMurchu
* REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
Post by skyhunter » Sat Jun 08, 2024 12:48 pm
How long are these things?!
Re: Anyone used this type of hood?
Post by TRDxB2 » Sat Jun 08, 2024 2:37 pm
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Sat Jun 08, 2024 3:46 pm
He’s got some nice stuff.
Russ T Fender
First Name: Val
Last Name: Soupios
Post by Russ T Fender » Sat Jun 08, 2024 9:46 pm
I use them on my '14 speedster with a stuck hood. Don't need them but I like the look!
skyhunter
First Name: Donncha
Post by skyhunter » Sun Jun 09, 2024 12:50 am
I am just wondering how long they are. I have a speedster and like this look, but not sure how long this is and if it will hit the steering column. Need to reconfigure the seat height and distance. Etc. Etc.
Post by TRDxB2 » Sun Jun 09, 2024 4:36 pm
Why don't you just contact the maker?
skyhunter
First Name: Donncha
Post by skyhunter » Mon Jun 10, 2024 9:36 am
I have had contact with them.
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Mon Jun 10, 2024 10:36 am
Out of curiosity, how long is it??
skyhunter
First Name: Donncha
Post by skyhunter » Wed Jun 19, 2024 10:44 pm
Nobody will say Les.
Post by Allan » Wed Jun 19, 2024 11:54 pm
The width of the top tank on the radiator is known,. It is simply a matter of scaling up that measurement against the photograph.
Hope this helps.
First Name: craig
Last Name: leach
Post by Craig Leach » Thu Jun 20, 2024 11:23 am
Considering that cold rolled steel generally come in 48" x 96" sheets & sheet metal brakes over 48" are rather costly. With the wired edge @ the
rear. the folded edge @ the front & compound angles to get a slight slope to the hood it would be impractical to make it more than 46". On my speedster with the steering column not quite as low as the one in the picture 43 1/2" would be the longest it could be. That is a neat idea, think
of how easy it would be to work on dash wiring with no cowl in the way :D
