Anyone used this type of hood?
Re: Anyone used this type of hood?
They make them
scroll down https://www.everettcurrierfarm.com/bodies-and-pricing
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
He’s got some nice stuff.
Russ T Fender
- First Name: Val
- Last Name: Soupios
I use them on my '14 speedster with a stuck hood. Don't need them but I like the look!
skyhunter
Topic author - Posts: 95
- First Name: Donncha
- Last Name: OapostropheMurchu
- * REQUIRED* Type and Year of Model Ts owned: 1916 Speedster
I am just wondering how long they are. I have a speedster and like this look, but not sure how long this is and if it will hit the steering column. Need to reconfigure the seat height and distance. Etc. Etc.
Why don't you just contact the maker?
skyhunter
I have had contact with them.
Les Schubert
- First Name: Les
- Last Name: Schubert
Out of curiosity, how long is it??
skyhunter
Nobody will say Les.
The width of the top tank on the radiator is known,. It is simply a matter of scaling up that measurement against the photograph.
Hope this helps.
Hope this helps.
- First Name: craig
- Last Name: leach
Considering that cold rolled steel generally come in 48" x 96" sheets & sheet metal brakes over 48" are rather costly. With the wired edge @ the
rear. the folded edge @ the front & compound angles to get a slight slope to the hood it would be impractical to make it more than 46". On my speedster with the steering column not quite as low as the one in the picture 43 1/2" would be the longest it could be. That is a neat idea, think
of how easy it would be to work on dash wiring with no cowl in the way
