Anderson timer lubrication
JimKelsey
Topic author - Posts: 12
- First Name: Jim
- Last Name: Kelsey
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Tudor
- Board Member Since: 2010
For those of you that use the Anderson timer, what type of lubrication do you use that gets the best conductivity?
Re: Anderson timer lubrication
Jim, I use white marine grease...I do not pack it...I just place a very small schmear on the flapper and 4 conductors. I clean it annually. The timer on my driver is 7 years old and shows very little wear.
