Lube or dry?
Topic author - Posts: 2320
- Last Name: Juhl
Lube or dry?
When installing rear wheels on axles do you put any oil or grease on the axle or leave it dry?
Kerry
- Last Name: van Ekeren
Re: Lube or dry?
Keywayed taper shaft/hub are ment to be a dry fit.
Re: Lube or dry?
Dry!
Aĺlan from down under.
Hal
- First Name: Hal
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: '22 TT Stake Bed, '18 Touring (Hers)
Re: Lube or dry?
Yep, what they said. If you put grease on there, it takes up some amount of space. then when you drive, some of that will work its way out. Now you have a loose fit.
- Last Name: Juhl
Re: Lube or dry?
Thanks! Makes sense.
Re: Lube or dry?
The fit of components on a tapered axle relies in friction to remain tight. The key is used to stop them moving. Using any kind of lubricant will reduce that friction, thus compromising the fitting. It is tempting to use something to make removal easier, but it defeats the purpose.
