wheel rim plated
Art Ebeling
Topic author - Posts: 515
- First Name: Art
- Last Name: Ebeling
- * REQUIRED* Type and Year of Model Ts owned: 1911 touring 14 runabout
wheel rim plated
Can someone recommend where to get rims galvanized in the midwest. I called two plating services and found that they have a 500.00 minimum. Does anyone sell re-plated rims or short of that what paint would look correct? Art
Billy Vrana
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
Re: wheel rim plated
Look up Oshkosh Plating, I had these done in 2018, pretty sure it was $160 or so, and they were done in a week. I sandblasted them with a fine sand and the turned out great
- Last Name: Patrick
[image][/image]Sherwin Williams has a very durable silver reflective roof paint called Silver Brite that, to me looks much more silver than galvanized, which, in a short time, becomes a dull grey. Silver Brite is very reflective and is very much like the original Model T plating, which I once read was cadmium plating and not galvanized and Silver Brite is very tough, will not come off or dull. Jim Patrick
- Attachments
- 8E292FD6-7F73-4A05-A346-BC96ABBF55B3.jpeg (20.72 KiB) Viewed 5919 times
...I once read was cadmium plating and not galvanized...
What you read was bogus, Jim. Cad plating was first used commercially in the thirties. Model T rims were galvanized.
In 2012 I had seven rims hot dip galvanized at the Valmont galvanizing plant in Claremore, near Tulsa, for the minimum charge at that time of about $235. If I'd had more rims I could have had up to sixty of them done for the same minimum. Not too long ago Ignacio got a bunch of guys to pool their rims and have a lot done in a batch for a lower cost per rim. Maybe he will comment here about how that worked out.
There are several Valmont plants in the Midwest. You can Google them.
Yes, galvanizing does lose its fresh brilliant luster over time. This is last August, eight years after plating. I think it still looks pretty good.
Thank you Steve. Sorry for my incorrect information. It is always good to correct bad information immediately for the benefit of all. Jim Patrick
- Last Name: Humble
A couple of years ago I looked at the Ford rim drawings at the Benson Ford Research Center specificity to see the plating notes. Ford drawings included Ford rims, Goodyear rims, and the other vendor made rims. Some specified galvanize, some specified zinc plated. None specified cadmium plated. Less Henrys book erroneously calls out cadmium plating for 21" rims, but that is not what is documented in the Ford drawings.
So, if hot dip galvanize is not practical consider your options for zinc electro plating.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Clear zinc plating looks very nice and most any plating shop can do it. Sandblast the rims 1st for a uniform appearance. Plating is not subject to the large lot charges for galvanizing.
Galvanized = zinc plated. Different terms for the same thing. Galvanizing/plating is done by two methods — hot dip and electroplating. I don't know which method was used originally on rims. At auctions I buy old galvanized nails by the can because they were hot dipped. The galvanized nails currently sold in hardware stores are thinly electroplated and soon rust. Maybe the shops that electroplate rims do a better job. I'm quite satisfied with my hot dipped rims.
For anyone with a small budget, such as a young high schooler who can’t afford the expense of plating, painting the split rims with “Silver Brite” is an excellent alternate solution. So satisfied am I with “Silver Brite” that, even though I have the means to afford plating, painting with Silver Brite would be my first choice, instead of an alternate solution to galvanizing or plating of any kind. Also, If the rims are not too pitted, try to avoid blasting so as to retain a smooth metal finish. Painting or plating over a rough, sandblasted finish will give you a rough finished result, instead of a smooth shiny result. Use Muriatic acid, instead, to remove the rust and after all the rust is gone (down to the bottom of the pits, thoroughly neutralize with a solution of baking soda mixed in water and apply to the rim until it stops bubbling, especially around the lugs. Quick dry with a heat gun to prevent flash rusting and when cool, prime with red oxide primer, then overcoat with Silver Brite. Jim Patrick
PS. If you do use Silver Brite it should be thoroughly stirred, not shaken. The Sherwin Williams salesman told me that shaking the can causes friction that can cause pressure to build up and the lid to blow off (what a mess that would make!). Also, when you are using it, constantly stir it because it is full of silver pigment that must remain suspended. When painting it on, it is so full of pigment that the painted surface appears to be uneven, but as the painted surface settles out, the brush strokes disappear, the surface becomes very smooth and uniform and shiny silver. Since it is for metal roofs, it is very durable and weatherproof and will provide protection and prevent rust. Also easy to touch up in case of a scuff. After 20 years, my rims still look great.
Dan McEachern
- First Name: DAN
You could also Powder Coat them silver. A friend recently informed me that Eastwood has a silver paint that is pretty durable and looks good so. . . . if ya can't locate the Sherwin Williams product, you can buy from Eastwood on line.
My experience with hot dip galvanizing is that it is much heavier and less uniform than the electrodeposited clear zinc. Hot dip is exactly that- the part is dipped into a bath of molten zinc. The rims in the above pictures do look very uniform, so I would imagine that the final result is dependent on the process and operator doing it.
Billy's rims look to be electro plated zinc, which I believe is the process originally used by Ford. Hot dip galvanising will last longer, but does leave a little rougher finish, and perhaps a few 'dribbles' which may need dressing own before tyres are fitted. Galvanising is used to describe both processes by some, but they are hardly equal. Hot dipping in molten zinc is a longer lasting finish. Electro plating gives a smoother, more even finish, at a more competitive price for smaller lots.
I have had occasion to freshen up electro plated zinc rims, and a brush on aluminised enamel called Silva frost does the job nicely. It does need constant stirring during application, looks duller at the time of application, but dries to a nice even finish.
The Silva frost is also used on copper head gaskets. One coat is allowed to tack dry, a second brushed on, and the heas fitted. The enamel makes an excellent sealant, much like Coppercoat I presume.
- First Name: Dennis
- Last Name: Seth
I have used a Rust-oleum product called Galva-oleum spray . It's a cold galvanize spray paint and it looks very close to factory galvanize and is available at the big box stores. Like all painting the prep work is the most important. If you don't clean and prep your rims you won't get a good finish.
- Last Name: Hatch
FYI You can clear coat your fresh plated rims, yes I said plated to keep them looking new. Zinc is used as a sacrifice coating, it will oxide. I have some rims I had plated about 10 + years ago clear coated with just spray can clear coat that look as good now as they did new.
I would get some rims plated now but that guy is out of business, thanks EPA. Dan
NU2theT
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
a great topic and on my spring to-do list. the pictured rattle can premium 7007 from Crown is what I might use, any input would be great.
- First Name: Adrian
- Last Name: Whiteman
Cold galv paint is useful, but fragile. The finish scratches and chips. Ideally it is used on metal, then primered then top coated.
That said, I have used cold galv for touching up welding and it has protected the fittings well for several years without being primered or top coated. That is in places off the ground where things don't usually rub or knock against it. As it just doesn't take kindly to things hitting it - such as stones on the road I would not recommend it as a durable option for wheel rims.
A 'good' silver paint on good primer is a better choise if plating/galvanising is not an option for you.
Art Ebeling
- First Name: Art
I called Oskosh plating and the will zinc plate five rims for 75.00. They said not to sandblast them as their cleaning solution wiuld take care of the rust. What are your opinions about that? Thanks for the responses. Art
Art, it depends on how good your rims are. I have mine sand blasted as a matter of course. It is a very good way to expose possible faults you may wish to eliminate. Blasting will reveal deep pitting, loose lugs, thin bead edges etc. Look upon it as cheap insurance to wards getting a good set of rims to plate.The rounded rim edges that are seen on the car can be sanded down to smooth out the sand blasted surface.
No doubt the plater's prep will degrease and remove paint, but removing deep rust like that found in some rims is not likely to be neutralised. If it is not, the plating may even take on the rusty flakes, but there will be a void between the edges of the flakes and the rest of the clean rim, and that leaves a path for continuing rust.
Hope this helps,
Hope this helps,
Hot dip, or electroplate? As Allan said, the former will last longer.
Susanne
- First Name: Susanne
- Last Name: Rohner
Go hot dip if you can. Back when I was a kid I sent my Hayes rims to be hot dipped, it was cheap (I think they charged all of $10 a piece, maybe less) and they came back prettier than a pyroxylin-dipped Packard...
Funny enough I remember the place I sent them to also did trash cans - hope working on the T parts weren't too much of a downgrade for them.
Darn, I miss that car.
Art Ebeling
- First Name: Art
I asked that and it is electroplate. Knowing that I will probably paint them. I had called other galvanizing shops and was given prices of around five to six hundred dollars for five rims which is mostly from a five hundred dollar minimum charge. ArtSteve Jelf wrote: ↑Thu Jan 21, 2021 10:19 pmI called Oskosh plating and the will zinc plate five rims for 75.00
Susanne
- Last Name: Rohner
Are they in the galvanizing business, or would they have to set up a special tank to do that? Seems WAY high to me... At that cost a 3 gallon pail would be a few hundred bucks... each.
Galvanized garbage can? That's a half grand can at a half a grand a piece...
Did they explain WHY it would be so cost prohibitive?
Tadpole
- First Name: Tad
- Last Name: Glahn
Digging up this old thread here because I am looking to get this done myself. Steve, I was in touch with a business that said they could hot dip galvanize my rims but are worried about the quality of metal the rims are made of and how uniform the reaction would be once they are dipped in the vat at 800 degrees. Can you remember, did you have any such concerns when you had yours hot dipped?
No, they were fine. I guess Ford's reputation for quality materials includes rims. I did have a few spots I had to hit with a small grinder to level them out. How many do I mean by "a few"? Dunno. That was a long time ago. As I recall, that was a very minor thing.
signsup
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
I have no idea how close this is or isn't to the original, but I like the look. It is Rustoleum soft iron on the demountable rims. Only the outer rim shows, but I like the contrast to the painted wheels. This is for a military vehicle, so that is why they are a shade of OD green. I think I'll leave the brass cap unpainted as I like that look on a military vehicle as well.
Beauty is in the eye of the beholder.
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
m_p_dean@yahoo.com
- First Name: Maurice
- Last Name: Dean
- * REQUIRED* Type and Year of Model Ts owned: 1917 Touring Car
I used the hammer finish Rustoleum in a light grey, not as good the old Hammerite, but they look good. Note that I live in AZ, and don't deal with a lot of water and corrosion.
Maury Dean
Maury Dean
I would ask Ignacio about his experience with galvanizing rims, but I can't look him up because of this:
WTH?
WTH?
kmatt2
- Last Name: Matthiesen
Steve, For Ignacio’s Model T , his car is a 1922 Touring with a 1925 engine.
