mystery wire
ecory0
Topic author - Posts: 90
- First Name: Eli
- Last Name: Cory
mystery wire
I pulled off my starter this evening and SURPRISE, this wire said hello to me. Any idea what it is? I will be taking the hogs head off tomorrow to get a better look. The other surprise was the broken bolt (bottom right). Got it out pretty easy though.
got10carz
- Last Name: Meixner
Re: mystery wire
The last one I found went to the Flux Capacitor. Made time travel very fast!!
ecory0
- First Name: Eli
- Last Name: Cory
Re: mystery wire
Lol, maybe I'll go back in time and find whoever put that wire in there.
mtntee20
- First Name: Terry & Sharon
- Last Name: Miller
Re: mystery wire
Is that a Braun speed sensor? As in Tachometer maybe? That might be a ground wire from one of the lower Bendix cover bolts. The wire would have to be out of the way for the Bendix engagement.
ecory0
- First Name: Eli
- Last Name: Cory
Re: mystery wire
I don’t have a speed sensor. Maybe in its past it had one and it was left there? Where would the wire lead to?
BHarper
- First Name: Bill
- Last Name: Harper
- * REQUIRED* Type and Year of Model Ts owned: '14 Touring, '20 TT Farm Truck, '24 TT Depot Hack, '24 Coupe, and a 1914 Metz Model 22 Torpedo Runabout
Re: mystery wire
Hi Eli,
On my car that red wire is for the magneto.
Good luck with your project.
Bill Harper
Keene, New Hampshire
ecory0
- First Name: Eli
- Last Name: Cory
Re: mystery wire
I should have circled the wire I was referring to. Its inside, the blue one.
Re: mystery wire
Whatever it is that's just plain crazy and get it out of there!!
I love the flashlight! Tell us where we can get one like that pls.
ecory0
- First Name: Eli
- Last Name: Cory
Re: mystery wire
the light is from Harbor Freight. You can find them on sale for about $22.
This one is similar. I couldn't find the kind I have but they are in the stores.
https://www.harborfreight.com/lighting/ ... 59103.html
mtntee20
- Last Name: Miller
Re: mystery wire
Eli, What is that mounted to the oil pan, just below the hole for the starter? It says BRAUN on it and is NOT original. I suspect it's some kind of speed sensor for rpm of the magneto/flywheel. Otherwise, there is NO electric wiring in the hog's head area other than the magneto to post.
Could it be a temperature sender of some kind?
Re: mystery wire
Pretty sure that's the "light bar" that was referred to above.
ecory0
- First Name: Eli
- Last Name: Cory
Re: mystery wire
The Bruan is a magnetic light.
As far as the blue wire, no clue. It wasn't connected to anything, just a hitchhiker.
If you didn't see my other post, I jacked up the magneto when removing the bell cover. Ugh....
- Last Name: Hatch
Re: mystery wire
Just we are all on the same page, you removed the “Hogs Head”.
That is what the transmission cover has been called since Edsel wore short pants.
Re: mystery wire
BRAUN object is the flash light illuminating the hole
