Which band adjustment via outside Hogshead RHD?
Rata Road
Topic author - Posts: 210
- Last Name: Weeds
- * REQUIRED* Type and Year of Model Ts owned: 1923 Depot Hack, 1927 Coupe & 1914 Runabout
I'm remotely helping a newbie with his TT, It had no Cab so he has made that, made a nice deck and he's got it running but no reverse or low gear band contact.
My cars are rugged up for the winter and I dont want to dig one out, I know the band adjuster locations are different on the right hand drive Hogshead.
Which ones are on the outside please?
Kevin
[attachment=0]Murrays TT.jpg[/attachment]
Kevin
Cordes_jeff
- First Name: jeff
- Last Name: cordes
- * REQUIRED* Type and Year of Model Ts owned: 25
Re: Which band adjustment via outside Hogshead RHD?
Outside band adjustments are opposite of LHD cars. Reverse and brake adjust from the outside.. I could be mistaken
Reverse and brake are on the outside and low is inside. Just the opposite of the left hand drive.
- First Name: craig
- Last Name: leach
I think that right hand drive are reverse & brake adjustable from the outside?
Only us " "Mericans " answering? Most of us including me (sic) have never actually worked on a right hand driven model T.
But yes, as the others have said.
Rata Road
- Last Name: Weeds
Thanks Guys
I thought Alan would have been in here lol
Rata Road
- Last Name: Weeds
He has just sent me some pics,
Doesn't look right to me, no shaft going through Brake band spring?
Its a 1925, looks later wider brake.
[attachment=0]Model T Trans Murray.jpg[/attachment]
- Attachments
- Model T Trans Murray.jpg (59.77 KiB) Viewed 2150 times
It does look like a wide brake band so it must have a 26-7 hogshead. Note the wider spacing between the brake and first gear pedal.It would also need a four dip pan to clear the wide band. Later pedal shafts are often this short variety. Personally, the full length ones which enter the adjusting screw I feel are more satisfactory and give more support for the shaft in use.
The first gear band/drum must be well worn to be adjusted up so much that the return spring is almost coil bound.
The brake spring is short a couple of coils.
Low seems to be missing the special notch washer, hence the extra jam nut.
speedytinc wrote: ↑Thu Jul 04, 2024 7:53 pm
Spring is too compressed? May be the drum is too worn?
That might be part of why he isn't getting low to work. Either the spring or the band itself may be "bottoming out" resulting in no low gear engaging.
New thicker lining may help for awhile, but a few things in there need to be corrected.
Brake spring has 2 less coils.
Low band ear needs a squeeze to keep the spring from between the ear & shaft.
Low band has enough wear the spring will be over compressed @ full engagement, may bind. Needs relining.
Rata Road
- Last Name: Weeds
Thanks guys,
Just got an email and he had the rear end jacked up before and once lowered to the ground low gear worked fine, adjusted reverse and that works fine now.
If it was mine I would be doing some replacement work in there like you suggest.
Always learning.....
Great feedback as always guys
Kerry
- Last Name: van Ekeren
And to debunk the myth that the removable ears can come off the band if fitted backwards from the rotation direction of the drums, RHD have the band fitted with the removable ears on the right side.
