New Birdhaven Catalog ??
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sat Jul 06, 2024 8:26 pm
Anyone received one of these catalogs yet?
Respectfully Submitted,
Be_Zero_Be
Re: New Birdhaven Catalog ??
Post by RajoRacer » Sat Jul 06, 2024 9:03 pm
Well, aren't we just special ???? And No, I have not !!!
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Post by BE_ZERO_BE » Sat Jul 06, 2024 9:05 pm
I'm not special (although I am Italian) - I just saw this on Facebook.
Be_Zero_Be
schwabd1
First Name: David
Last Name: Schwab
Post by schwabd1 » Sat Jul 06, 2024 11:26 pm
Hmmmmm...... I wonder if all the unavailable parts are listed in the catalog?
Will_Vanderburg
First Name: William
Last Name: Vanderburg
Post by Will_Vanderburg » Sun Jul 07, 2024 1:18 am
That one is mine. Just got it yesterday. Most of the listings are parts you can get from most other suppliers.
Rebuilt KW coils are listed available as well as the polymer plastic coil box rebuild kits
The voltage regulators with modern innards are listed as available. But I haven’t studied it thoroughly yet.
William L Vanderburg
1922 Center Door Sedan
Will_Vanderburg
First Name: William
Post by Will_Vanderburg » Fri Jul 12, 2024 11:35 pm
So I’ve perused the catalog and the only definitive Fun Projects part I’ve found is the polymer plastic coil box rebuild kit and possibly a voltage regulator and brass magneto post.
Catalog says all are in stock.
The brake light kit is not mentioned.
The parts are not identified as to who originally produced them, but the mag post photo image is the same one that was on Fun Projects website.
As far as Bob’s goes, I think the KW coil parts came from him but the correct spring mounting bolts with the thicker heads are not listed.
Texas T Parts alternators and distributors are listed and the Sure Stop brake conversion is listed.
