So filling up today noted the cardboard pieces are pretty well spent and would like to replace them. This is a 26 Fordor and mine are in two pieces (picture 3).
Putting them together as when under the seats the width is approx 16 3/4" and the length is approx 31 1/4". I did not see replacements for these in the various auto parts catalogs I have, any measurements would be great, thanks in advance.
under front seat cardboard replacement
- Last Name: Jablonski
Re: under front seat cardboard replacement
Since you have your gas tank under the front seat, you have two spring cushions to sit on with two separate "springboards ". I do not have the dimensions in my records, but I did replace those boards using what was left as a template, instead of replacing with cardboard. I did use 1/8 inch plywood.
- First Name: Art
- Last Name: Mirtes
My 1923 touring came to me with two pieces of cardboard under the front seat. After 45 years, the cardboard pieces were worn out and were replaced with a single piece of 1/8 inch thick plywood. Cleats were added to maintain proper positioning so that the cushion goes in its proper place.
Art Mirtes
Art Mirtes
- First Name: Jack
- Last Name: Putnam
Langs did have the cardboard that covers the tank. I got mine for my 25 fordor from them .
Jack, too bad they don't list it in their catalog anymore
Topic author - Posts: 214
- Last Name: Wendt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor
just placed an order the other day and did'nt think to ask due to no listing, will check in the a.m. Thanks Jack
