Sealed Rear Axle Bearings
MikeSommers
Topic author - Posts: 48
- First Name: Mike
- Last Name: Sommers
- * REQUIRED* Type and Year of Model Ts owned: 1913 Touring
Are the sealed inner and outer bearings worth the expense? I have never talked to someone who has them, so I am wondering about the users' experience on this forum.
Regards,
Mike
Regards,
Mike
MikeSommers
- First Name: Mike
Re: Sealed Rear Axle Bearings
I am referring to the rear axle bearings...
Do you mean safety hubs and; https://www.modeltford.com/item/2508IRB.aspx (Modern inner rear axle bearing kit)
You will note the bearing is only listed for inner install.
Mike, Langs has them both, the outer are $198 ea., and the inner are $125 each, so it does get pricey.
I think you have to do some machining for the inner bearing. My '13 came with them when I bought it, so far, so good.
Hope this helps.
Hope this helps.
tdumas
- First Name: Ted
- Last Name: Dumas
- * REQUIRED* Type and Year of Model Ts owned: 1927 Coupe, 1924 Touring
Get some good used Hyatt bearings and save the money for other work on your car.
To me $600 invested in rear axle bearings
would kill my Scotch soul.
Ruxstel24
- Last Name: Hanlon
My touring with a Ruckstell has had sealed bearings in it for probably 50 years.
No muss, no fuss, no leaking into the brakes.
I imagine they were a little less pricey then.
Sorry, no grease cups...
Ted has the right idea, at least for the inner bearings. They are listed for inner axle use only. Reading between the non existent lines, it may be that they are not capable of carrying the load at the wheel end of the axle. To be able to fit a ball bearing in the space occupied by 1/2" hyatt rollers and the sleeve means the balls themselves must be quite small. The smaller the bearing, the less load it can carry. Safety hubs on the outer end of the axle use a much larger bearing.
I could be wrong.
I could be wrong.
MikeSommers
- First Name: Mike
Allan,
I believe these are not ball bearings, but rather timkin. They seem a bit pricey, but why not use the best technology available, especially if it doesn't affect the look of the car.
- Attachments
- Bearing.jpg (13.72 KiB) Viewed 8105 times
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Seems to me if you want to improve things and not just replace one type of bearing for another, safety hubs would be a much better choice. At least if you break an axle, the wheel won't fall off with safety hubs.
MikeSommers
- First Name: Mike
Thanks Dan,
I thought about that, and a friend in our Model T club (KCChuggers) reminded me that even in an axle break, if you had disc brakes, the calipers would prevent the wheel from coming off.
I resisted the thought of disc brakes... but then, Frank drove home the wisdom, "safety trumps authenticity".
That was great advice!
Mike
Mike
Mike, Timken is a brand of bearings. They make all sorts of bearings for a multitude of applications. I do not know what type of bering is used in that set-up. The carrier looks to be a separate piece, of thickness greater than the original sleeves if it has that O ring on the end. This may mean the bearing is a roller bearing, and that would be considerably shorter than the originals and most likely of lesser diameter rollers.
I second Dan's thoughts on safety hubs.
The caliper holding the wheel on is not a guaranteed thing. Just depends on where exactly the axle break occurs. If the axle breaks even with the wheel hub, my bet is that the wheel is gonna leave you. "You picked a fine time to leave me loose wheel....."MikeSommers wrote: ↑Tue Jun 11, 2019 6:43 pmThanks Dan,
Mike
While I don't have one of these sets in my hand, it is clearly shorter than Hyatts and very likely much much stiffer. This is not a combination that leads me to believe axle breakage will be reduced. If you want a seal, put in a seal. I own 4 Model T's...if safety was my first priority, I would sell them, not butcher them. You're kidding yourself, anyway, if you think disk brakes make you safe on the road. It's a Model T...you're never really safe, and no accessory is going to change that...if that's an issue, you're sinply in the wrong hobby.
I think this is what you get when you over-protect your children at the expense of life experience.
Keep it original. Buy those new aluminum caps if you must, but don't change any of the factory specifications.
Jeff Hood
- Last Name: Hood
- * REQUIRED* Type and Year of Model Ts owned: 1915 Touring, 1923 Fordor, 1924 Martin Parry Canopy Express, 1925 Coupe
As far as a caliper keeping the wheel in place, it also depends where the caliper is mounted. Where I worked, I got a call one afternoon that one of our police spec Crown Victorias was stuck on the bridge with a bad transmission. The car wouldn't move forward or reverse, so I sent a tow truck to retrieve it. The driver picked it up by the front and towed it down the bridge then turned around and towed it back over the bridge and on to our shop. Upon arrival I asked him to back it into one of the shop bays, and he pulled forward to square up with the bay door and began to back up. As soon as he started moving backwards the right rear wheel turned out and detached from the vehicle. The axle had broken right in the bearing and the rear caliper was mounted on the leading edge (forward) and as long as the car was being towed forward the caliper kept the wheel in place, but as soon as he started to back up, the wheel and stub came out of the bearing and off the car.
The calipers on a Model T disc brake setup are on the lower trailing edge and most likely will not keepthe wheel on the car while moving forward.
