Vaporizer or NH
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Vaporizer or NH
Post by Dave Young » Sun Jul 21, 2024 4:57 pm
I own a bunch of T’s but know nothing about the Vaporizer. I buddy of mine has a ‘27 and is having trouble getting it to perform well. He drove it on the MTFCI Michigan tour all week and we messed with it whenever we had a chance. After the usual coils, timer, timing, and fuel flow corrections, it’s still not nice to drive. I, of course, lean toward getting rid of that carb and just going with the NH only because I understand them. What’s the opinion of others? In order to switch it to an NH, does a different throttle arm need to be added to the throttle rod? He knows that he’ll need new manifolds and a different valve cover.
Moxie26
Last Name: Jablonski
Re: Vaporizer or NH
Post by Moxie26 » Sun Jul 21, 2024 5:24 pm
Vaporizer system is unique. First off, it has an weighted air valve on the intake, A hot plate section that has to have a true surface to be mounted and to be compressed so that there is no air leakage from the outside going in to the mixture, may use the larger gas float, a different spray nozzle/ mixture needle adjustment, different throttle and choke linkages..... Our 26 runabout came with a vaporizer set up that did run the engine very well. ........ when I did switch to the NH, I used a straight through NH from 1920, an original 1912 larger aluminum intake, nos Ford exhaust manifold and installed a connector on the throttle rod to connect the NH along with new linkage to operate the choke on startup, and gas mixture...... So why did I put an NH on the engine?? I purposely changed to get more power with standard parts , sacrificed the economy of the vaporizer.
Dave Young
First Name: David
Last Name: Young
Re: Vaporizer or NH
Post by Dave Young » Sun Jul 21, 2024 5:45 pm
Hey, Bob. Power wins every time! We just got back from Michigan and that E Timer gave me another 800 miles of flawless performance on the 26 Touring. If you ever decide to do a national tour, Scott can haul your buggy for you.
Moxie26
Re: Vaporizer or NH
Post by Moxie26 » Sun Jul 21, 2024 5:56 pm
Dave ............Don't get me wrong, I did have those parts in stock. The engine ran great with that vaporizer... So why did I change everything,.... With the talk on the Forum at the time with others comparing different carburetors and setups led me to change over. Do I regret the change, no I don't. I still have a vaporizer. I always appreciated your help and and Scott's , as always we'll keep that in mind. Thanks again !
jsaylor
Last Name: Saylor
Re: Vaporizer or NH
Post by jsaylor » Sun Jul 21, 2024 6:41 pm
The parts vendors sell an over the top linkage adapter, so no need to change the throttle arm on the steering column or replace the valve cover. an NH with a Scott Conjer high flow needle valve will make your T very dirveable.
John Codman
Last Name: Codman
Re: Vaporizer or NH
Post by John Codman » Mon Jul 22, 2024 11:52 am
There is a reason why the later Ts were almost all converted to the NH. I actually have never seen a vaporizer-equipped Model T Ford.
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Vaporizer or NH
Post by Russ T Fender » Mon Jul 22, 2024 12:28 pm
My car came with a vaporizer and it ran well but was impossible to start cold with the hand crank so I made the switch to an NH. It did start cold OK with the starter using full choke while cranking but I rarely use the starter on my cars and didn’t want to have to use it on my ‘27. I used the over the top conversion and it works fine.
Dave Young
First Name: David
Last Name: Young
Re: Vaporizer or NH
Post by Dave Young » Mon Jul 22, 2024 12:42 pm
Is there much to change with the choke pull/ needle adjusting rod?
Moxie26
Re: Vaporizer or NH
Post by Moxie26 » Mon Jul 22, 2024 1:19 pm
Linkage on the '26
Russ T Fender
First Name: Val
Last Name: Soupios
Re: Vaporizer or NH
Post by Russ T Fender » Mon Jul 22, 2024 5:16 pm
Here is my set up
Scott C.
Last Name: Clements
Re: Vaporizer or NH
Post by Scott C. » Tue Jul 23, 2024 12:44 pm
You will need a shorter fuel control/choke rod. The one that runs up through the dash. Here are pictures of with vaporizer and then with an NH.
Dave Young
First Name: David
Last Name: Young
Re: Vaporizer or NH
Post by Dave Young » Wed Jul 24, 2024 9:30 pm
Thanks for the photos!
bowerss2
First Name: Stephen
Last Name: Bowers
* REQUIRED* Type and Year of Model Ts owned: 1927 Roadster; 1926 Speedster; 1912 Torpedo
Re: Vaporizer or NH
Post by bowerss2 » Thu Jul 25, 2024 10:09 am
I have a 27 with a vaporizer. Its very "meh" It runs, but you cant hand start it cold. Im either going to convert it to a NH or just sell the car. Not because of the vaporizer haha, but i have too many Ts.
bron-hertford-nc
First Name: Bron
Last Name: Prokuski
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster, !926 Fire truck - Martin Parry Transporter
Re: Vaporizer or NH
Post by bron-hertford-nc » Sat Jul 27, 2024 9:18 am
Have had a Vaporizer T since 2013 .When I got it had been stored for 41 years. Cleaned out the carb and replaced the Vaporizer Heating Plate which had burn holes. Starts and runs perfectly. If it starts to be hard to start I know it will be time to change the Heating Plate ( part # 6273 in Lang's). Carry one as a spare. Only takes one little hole to really lean out your mixture.
Chris Barker
First Name: Chris
Last Name: Barker
Re: Vaporizer or NH
Post by Chris Barker » Sat Jul 27, 2024 12:39 pm
I have run my '26 with a Vaporizer for 22 years.
From cold it it always start if I turn 4 compressions with full choke first, before turning on the ignition.
And never start if I don't!
