No, it's not what you think. Im not revisiting that topic again. but, want to offer something out to the group. I guess I have an aftermarket T radiator that came on my 27 Depot Hack. My hood shelves are a good 1" gap from the bottom edge of the hood sides and my hood hold downs are stretched to the limit, but do manage to clip on.
But, my upper radiator hose was too short for the replacement kits from the vendors. My upper hose, instead of the standard 2" diameter by 4 inches long is almost 8" long.
Long story short, I purchased 2" diameter black rubber hose and cut mine to length and it looks and works great. But, I had to purchase a 36" length from NAPA to get this hose. I see no need to put the remaining 28" on the shelf. So, if anyone else has the need for a slightly longer upper hose , if you cover postage, I will gladly cut to lenght what you need and give it to you.
I can take a pic if needed.
Let me know how to help.
Upper Radiator Hose Too Short?
signsup
Topic author - Posts: 472
- Last Name: Brough
- * REQUIRED* Type and Year of Model Ts owned: 1915 War Wagon 1927 Depot Hack 1927 TT
A bunch of old cars
Sometimes they run.
Sometimes, they don't.
A bunch of old cars
Sometimes they run.
Re: Upper Radiator Hose Too Short?
I had posted this back then. For 1917-27 get a Model A hose set, trim to fit
signsup
- Last Name: Brough
That would have worked as well. but, only the 30/31 set would have given me the needed lenght for the upper hose. But, it would have worked as wel. Thanks for that info.
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
John Codman
- Last Name: Codman
I bought a hose set from Lang's for my '27 in 2014. The upper radiator hose is six inches in length; it fit perfectly.
signsup
- Last Name: Brough
As I mentioned, my radiator is an aftermarket and appears to be higher than the standard Model T radiator, hence, the need for a longer hose. But, I have read previous years threads about other having a similar need. I am sure with thousands of hoses sold, the vendors have the correct length for the correct fitment.
Did not mean to imply otherwise.
A bunch of old cars
Sometimes they run.
A bunch of old cars
Sometimes they run.
I "think" that several good pictures are needed of your radiator, full front, including some of the frame and fenders, back side high and low including good pictures of the top tank itself, mounting brackets/bolts etc, and firewall included in a long-side shot as well as how well the hood fits (if it is on the car?), in order to figure out what is off.
I have had several old era after-market radiators myself, and some of them did need a slightly longer upper radiator hose than the original Ford radiators used. However, your descriptions seem more than a bit excessive. Without being able to really see it, or good photos thereof, all we can really do is wonder and speculate. But something sounds way off.
