What is this?
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
What is this?
Post by got10carz » Wed Aug 14, 2024 4:27 pm
Volt meter says Readrite Meter Works Bluffton Ohio.
With the 22 1/2 highlighted makes me wonder if it's for checking Mag output?
Last Name: Wrenn
Re: What is this?
Post by TWrenn » Wed Aug 14, 2024 4:52 pm
Bluffton Ohio!...thats Forum member Jack Putnam's neck of the woods! :lol:
Re: What is this?
Post by Jerry VanOoteghem » Thu Aug 15, 2024 6:27 am
It's for checking radio batteries. In the early to mid 20's, radios were battery powered. They used "A" batteries for the tube filaments @ 6V, and "B" batteries for the tube "plate" voltage, with taps for 22-1/2 & 45 volts.
Erik Johnson
First Name: Erik
Last Name: Johnson
Re: What is this?
Post by Erik Johnson » Thu Aug 15, 2024 9:26 am
It's a typical 1920s pocket DC voltmeter.
It won't work for checking Model T mag output which is AC.
It can be used for a variety of applications, not just radio batteries.
It's a common item - not rare. I have a couple of them and regularly see them at estate sales and swap meets. I also have a pocket ammeter.
They usually have a wire with a probe attached to the top terminal or a permanently attached wire.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Re: What is this?
Post by mtntee20 » Thu Aug 15, 2024 11:48 am
NOTE: While it would work for 6 volt batteries, it would not be too accurate. ALL gauges and meters are most accurate at approximately middle of the face range. Thus, the 22.5 volt spot, would be accurate while the 6 volt and 45 volt reading would be "close" but not as accurate as 25 volt, exactly at mid range.
Thus, the designer had determined the 22.5 volt reading as being the most important, to ensure proper operation of the device being inspected, but required a 50 volt maximum to include the 45 volt secondary inspection point. Starting the range at 0, the meter could be used for low voltage DC measurements and MIGHT be close enough OR just serve as a "Go / No Go" indicator.
Re: What is this?
Post by Jerry VanOoteghem » Thu Aug 15, 2024 11:52 am
I don't think anyone expected or needed this to be a precision instrument.
John Codman
Last Name: Codman
Re: What is this?
Post by John Codman » Thu Aug 15, 2024 11:57 am
For years I had a Zenith Wavemagnet radio that looked like a small suitcase and it had two batteries - one of which was a 90 volt "B" battery. If you touched both terminals once, you would never do it again. I wish that I knew what happened to it.
Re: What is this?
Post by TRDxB2 » Thu Aug 15, 2024 12:59 pm
Looks like this when complete with all its parts
https://www.ebay.com/itm/166920629637?_ ... 1506.m1851
mtntee20
Last Name: Miller
Re: What is this?
Post by mtntee20 » Thu Aug 15, 2024 2:08 pm
My guess is that 22.5 volts isn't accurate enough.
Re: What is this?
Post by Jerry VanOoteghem » Thu Aug 15, 2024 4:00 pm
Not sure what you're getting at. If you've ever operated an early 20's radio, you would notice that they'll operate just fine at anything even close to the specified voltages. For that purpose, this volt meter is more than adequate.
