Fun Projects brake light switch
Belliott3
First Name: Bill
Last Name: Elliott
* REQUIRED* Type and Year of Model Ts owned: 1916 Model T Touring
Board Member Since: 2006
Post by Belliott3 » Fri Aug 16, 2024 7:33 am
Are the vendors no longer selling the amazing Fun Projects brake light switch? I can’t seem to find one anywhere, and they were great! The ones that attach to the transmission cover are a pain. If anyone has an old one they would part with, I’d be interested.
Last Name: Strange
Re: Fun Projects brake light switch
Post by CudaMan » Fri Aug 16, 2024 7:52 am
Out of production, as far as I know. :(
Last Name: Wrenn
Post by TWrenn » Fri Aug 16, 2024 8:02 am
The people down in Texas once said they were but never did seem to follow through. Too bad 'cause it was the best switch around. I love mine!! Hope ya find one somewhere Bill!
Post by TRDxB2 » Fri Aug 16, 2024 10:50 am
NO seems to be the consensus. Discussed before with alternatives & pictures of solutions
viewtopic.php?t=28117
viewtopic.php?t=41419
https://www.cool386.com/brake/brake.html
FP switch parts
Post by DanTreace » Fri Aug 16, 2024 11:10 am
Bill
If the strap over the tranny cover is cumbersome for you, try the other style of push-button switch at Lang's, no holes, and attaches to the frame rail. I use both and think these styles are even better than the Fun Projects that has the return spring to the brake pedal and the bolt on u-joint bracket.
Lang's Strap type:
IMG_7133 (550x413).jpg (123.57 KiB) Viewed 2261 times
Lang's Frame mount type:
IMG_2337 (600x450) (580x435) (570x428) copy.jpeg (92.03 KiB) Viewed 2261 times
Many parts to mount with that Fun Projects, the spring always gets stretched too much, or slips at the wire clamp screw, operates intermittently in my use.
Charlie B in N.J.
First Name: CHARLIE
Last Name: BRANCA
Board Member Since: 2010
Post by Charlie B in N.J. » Fri Aug 16, 2024 12:18 pm
That kit was worth the price for the bracket alone.
Post by RajoRacer » Fri Aug 16, 2024 1:53 pm
Anyone recall what the selling price was on those ?
Last Name: Wrenn
Post by TWrenn » Fri Aug 16, 2024 4:03 pm
Somewhere around $40 ish? My memory aint so good tho!! :lol:
