Trying to match my 21” rim type. FOUND!
Hangmancalif
First Name: Lee
Last Name: Adams
* REQUIRED* Type and Year of Model Ts owned: 1926 Model T coupe
Post by Hangmancalif » Sat Aug 17, 2024 1:25 am
As I hunt for a spare rim, I want to make sure I match the four that are on my ‘26 coupe. I’ve attached a few pics if anyone can figure out what I have and what I need to look for. Any help would be appreciated.
Kerry
Last Name: van Ekeren
Re: Trying to match my 21” rim type
Post by Kerry » Sat Aug 17, 2024 1:39 am
26/7 Canadian Ford split rims
Hangmancalif
First Name: Lee
Last Name: Adams
Post by Hangmancalif » Sat Aug 17, 2024 2:17 am
Kerry, thanks so much. Do i need to match exactly or will any other 21” rim work? I appreciate your help and finding such a rim quite elusive. Cheers.
Kerry
Post by Kerry » Sat Aug 17, 2024 3:17 am
The only difference is that the Canadian ones have the holes near the split rim for the spreading tool, also yours has a home made split lock. I have bought USA rims before and used on Canadian T and fit OK.
Last Name: Humble
Board Member Since: 2006
Post by Humblej » Sat Aug 17, 2024 6:45 am
All 21" split rims will be interchangeable.
Kerry
Post by Kerry » Sat Aug 17, 2024 8:23 am
Still have to know what to look for in finding rims, the 21" Chev looks the same but the valve for the tube does not line up with the Ford wheel felloe.
Hangmancalif
First Name: Lee
Last Name: Adams
Post by Hangmancalif » Sat Aug 17, 2024 6:26 pm
Thanks to you all. This info greatly helps. I’m a bit surprised how elusive these things are but I will keep looking.
Kerry
Post by Kerry » Sat Aug 17, 2024 7:18 pm
They are being made new again in England. veterancarrims.co.uk and they have Snyders in the USA as an agent to supply.
Post by Allan » Sun Aug 18, 2024 12:25 am
When I looked up veteran.co.uk I found a Scottish old time music site!
Vintage rims in Australia are also producers of new ones.
Kerry
Post by Kerry » Sun Aug 18, 2024 3:32 am
Try it now Allan, I was a few letters short on that web site link. veterancarrims.co.uk
Post by Allan » Sun Aug 18, 2024 7:59 am
Found it Frank. Conversations with Kiwi friends about the sale of the NZ business to the UK were all about the machinery being shipped out, but they were not aware of it ever being re-comissioned. It looks like it may be on the go again. My only thoughts were about the rolled BE rims for T's. Reports were that the NZ made ones were of lighter material than that used by Vintage Rims Australia, and were of a slightly different profile in the bead.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Sun Aug 18, 2024 9:19 am
I bought one Model T with demountable rims that had one wheel with two valve stem holes drilled in it.
I later learned that wheel had a Chevy rim that fit the same way.
Later, I found and bought two new old stock rims that turned out to be Chevy rims.
You learn most things the hard way with a Model T.
Post by Mark Gregush » Sun Aug 18, 2024 9:47 am
You can use the Chevrolet rims by drilling a new valve stem hole in the correct place.
