Early Coil box identification
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Sun Aug 18, 2024 5:49 pm
I picked these up recently. Just wanted to get a positive identification. The one on the left is narrower than the other one. Is it a Kingston and the other one a Heinz? What years?
Junk poor
First Name: D
Last Name: Brown
Re: Early Coil box identification
Post by Junk poor » Mon Aug 19, 2024 9:31 pm
Bueller..Bueller…
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Mon Aug 19, 2024 9:54 pm
The box on the right is Heinze.
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Mon Aug 19, 2024 10:34 pm
So the Heinz would be 11-13 and the other one would be a Kingston then? It takes a quite a bit smaller coil than the Heinz, even smaller than the Ford coils. That would make it 11-13 also. Does that sound right?
Post by John kuehn » Tue Aug 20, 2024 2:16 pm
I think this earlier post will answer your question. Hope this helps. http://www.mtfca.com/discus/messages/59 ... 1465417725
I don’t know if both coil boxes you posted are Ford T coil boxes but the earlier MTFCA info shows the differences of the early T coils themselves.
You also can go the home page of the MTFCA website then go to resources and then the old MTFCA encyclopedia where you can see a detailed information section of the coil boxes from beginning to the end of T production. Lots of information.
Woody23
First Name: David
Last Name: Woods
Post by Woody23 » Wed Aug 21, 2024 12:35 pm
The box on the left with the vertical 10/32 studs is a Kingston box. The stud was to hold the coil in place. I attached a photo of the brass tab on the coil.
David
Junk poor
First Name: D
Last Name: Brown
Post by Junk poor » Wed Aug 21, 2024 1:46 pm
Ok that makes sense. I wondered what those were all about.
Luke Chennell
First Name: Luke
Last Name: Chennell
* REQUIRED* Type and Year of Model Ts owned: 1920 speedster
Post by Luke Chennell » Sat Aug 24, 2024 12:35 am
The box on the right is a 1912 Heinze box with the coils arranged in mismatched fashion. The earlier Heinze coils in 1911 used a separate post to "ground" the top, and had combinations of more screws to hold the tops down. The Heinze company must have been a favorite of whoever was selling blueprint supplies to them, because the designs changed constantly.
