Looking for Wiring Diagram for Non Starter Ignition Switch
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Mon Aug 19, 2024 1:03 pm
Help needed for wiring diagram for the rectangular, dash mounted, ignition switch that has a 3 wire setup in place of the ammeter. I am told this was for the non starter cars 1919-1925.
MODEL T FORD DASH BOARD IGNITION SWITCH FOR NON.docx
(730.07 KiB) Downloaded 111 times
BE_ZERO_BE
First Name: BOB
Last Name: CASCISA
Re: Looking for Wiring Diagram for Non Starter Ignition Switch
Post by BE_ZERO_BE » Mon Aug 19, 2024 1:09 pm
Respectfully Submitted,
Be_Zero_Be
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Aug 19, 2024 1:09 pm
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Mon Aug 19, 2024 1:20 pm
Bob & Tad,
Thank you for the speedy reply.
Have a great day,
Don
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Mon Aug 19, 2024 4:41 pm
Why did Ford provide a BAT terminal on the early cars with magneto only ignition? I see nothing connected to it but there must have been a reason it was installed.
Paul
Don Demio
First Name: Don
Last Name: Demio
Post by Don Demio » Mon Aug 19, 2024 5:58 pm
Paul.
I am not sure why. A possible explanation may be that the ignition switch suppliers, such as Briggs and Stratton, Clum Mfg. , only offered a few types of switch because a change like this was not cost effective for so few a number of vehicles. These switch manufacturers provided components to many different car companies. As a retired member of law enforcement, I know that in the early 1970's it would have cost more to delete air conditioning on police cars than for an agency to take the cars as produced.
Don
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Aug 19, 2024 6:51 pm
There was a set of four A Type batteries (AKA Telephone Batteries) to start the T and slow cranking did not provide enough current from the Magneto in all cases.
Some Magnetos were hot enough to provide a spark to get the engine running.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Mon Aug 19, 2024 6:54 pm
Those non-electric cars also had a ring gear on the starter, so you could buy the electric components later when you had more money or got tired of cranking or broke your arm.
Post by speedytinc » Mon Aug 19, 2024 7:04 pm
WHAAAAAT?????
Tadpole
First Name: Tad
Last Name: Glahn
Post by Tadpole » Mon Aug 19, 2024 7:45 pm
I believe having a battery on board to assist with starting was popular on cars without electric start. You would crank it on BAT then flip it to MAG for driving. Later charging your battery or dry cells while the car wasn’t in use. I assume you charged old dry cells? I can’t pretend to know much about them.
Post by Allan » Tue Aug 20, 2024 7:12 am
It is likely that all flywheels came with ring gears once the starters were introduced. Having two distinct parts for the same job is not something That would be appreciated on an assembly line would. Ditto for the hogsheads, they were likely all the same, with factory blanking plates for non starter cars.
Many TT's were thus equipped, as a cost saver for commercial users.
