I am working on a finishing and assembling a reproduction 1909 Coil Box that uses wires to connect the switch to strips like original. I believe the originals were a solid strand wire. Maybe 20 or 22 gauge??
Any recommendations on what to use in todays environment (wire size, -and stranded vs. solid)??
Early Coil Box Wire recommendations...
BRENT in 10-uh-C
Topic author - Posts: 468
- First Name: Brent
- Last Name: Terry
- * REQUIRED* Type and Year of Model Ts owned: 1909 Tourabout, 1914 Runabout, 1914 Touring, 1916 Speedster, 1925 Speedster, 1926 Hack
Re: Early Coil Box Wire recommendations...
Original was 18ga. Single strand, cloth covered. Lang’s sells it.
But have used stranded and tinned the strands for hook shaping, or soldering. IMO stranded resists beaks, have taken apart the metal coil box switch mount and found busted solid wire at the sharp bend to the wood panels.
Plastic covered stranded replacement wires.
BRENT in 10-uh-C
- First Name: Brent
- Last Name: Terry
Thanks Dan. I stock 18ga cloth braided wire anyway, so I will tin the ends and form loops onto the ends.
Daisy Mae
- First Name: Kurt
- Last Name: Andersson
2nd on Dan
I had no continuity thru my switch, the common lead to the coil box strip had corroded at the switch lug and broke...
I replaced with stranded with soldered tips....nobody sees those wires anyway to argue purity...
