1917-1922 Coupe height?
Roger Byrne
First Name: Roger
Last Name: Byrne
* REQUIRED* Type and Year of Model Ts owned: 1911 Torpedo Open Runabout, 1914 Touring, 1912 Speedster (in progress) 1927 Touring
Post by Roger Byrne » Mon Aug 26, 2024 8:04 pm
I need some information. What is the height of a 1917-1922 Coupe at its highest spot? I would like to know how tall a rear enclosed trailer door would need to be and also to see if it would fit through the garage door. Thanks.
Preserving Mechanical History for Future Generations since 1965
Re: 1917-1922 Coupe height?
Post by Wayne Sheldon » Mon Aug 26, 2024 8:15 pm
The 1917 "hump top" is taller than all the later ones by a few inches.
As always, vehicle height varies considerably for tire brand, size, and condition. Also spring's and shackle's condition. But the big one is accessory shock absorbers can add an inch or more.
George Danek
Last Name: Danek
* REQUIRED* Type and Year of Model Ts owned: 1918 Coupelet, 1920 Runabout, 1923 Touring
Board Member Since: 2014
Post by George Danek » Tue Aug 27, 2024 2:16 pm
Roger, Height from ground to top on my '18 is 81" with 30x3's in front and 30x 3-1/2's in back. Fits in a garage opening of 82' no problem. George
NoelChico
First Name: Noel
Last Name: Chicoine
Post by NoelChico » Tue Aug 27, 2024 9:37 pm
Something to consider with enclosed trailers is the presence or absence of a "beaver tail" downward sloping floor for the rear 2 feet. This allows a tall car to sneak under a rear sill in an otherwise tall enough interior. This is more important with enclosed cars aside from coupes, and tourings with the tops up.
Roger Byrne
First Name: Roger
Last Name: Byrne
Post by Roger Byrne » Wed Aug 28, 2024 10:34 am
Thanks George, that's the info I was looking for. Apparently we have the same garage door height. I can get my 1914 in with the top up but I wasn't sure if maybe a coupe of that period was a bit taller. Thanks Noel, I've never had an issue with a trailer but figured I'd check with the forum anyway.
Post by Jerry VanOoteghem » Wed Aug 28, 2024 10:59 am
Be sure to account for the car bouncing while being trailered and allow for it with internal ceiling height.
