Updated website : Starters, generators and Voltage Regulators
Moxie26
Last Name: Jablonski
Post by Moxie26 » Sun Aug 11, 2024 12:18 pm
Updated and comprehensive website for quality Model T needs at : www.modeltstarters.com Thank you Jeff Stevenson.
John Codman
Last Name: Codman
Re: Updated website : Starters, generators and regulators
Post by John Codman » Sun Aug 11, 2024 12:29 pm
Thanks for posting that!
AdminJeff
Post by AdminJeff » Thu Aug 22, 2024 5:09 am
Free advertising! I love it. Yes, it is a complete & professional redo. Interestingly, the new logo was one contest I ran (winner was from Spain) and the site design was also a contest and that winner was a whiz kid from Pakistan. He even coded the entire site for me now that I have better things to do.
I'm almost ready to add my starter/generator brush plate rebuild kits to the shop. I'm now fabricating ALL of those components - brush holders, springs, insulators, backing plates, etc. Even the brush plates are being made. Reproducing the Starter/generator carbon brushes are this winter's project. Literally Every single Model T still on the road will need each of these parts at some point.
It's not sexy, but somebody had to do it.
Re: Updated website : Starters, generators and Voltage Regulators
Post by TXGOAT2 » Fri Aug 23, 2024 1:30 pm
Unseen, but vital parts!
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Fri Aug 23, 2024 2:03 pm
I think this is a very exciting project, one I have been following here on the forum. I bought one of the Fun Projects regulators years along with a very nice ammeter for my '23. The ammeter was needed for adjusting the third brush if I recall correctly. This was a set and forget installation, I never even have to think about it, its that good.
Now I'm working on a '14 with an 18 motor that has a starter & generator. There is no ammeter. Can these new regulators be used? Do they need adjustment of that third brush? How would this be done?
Paul
Post by speedytinc » Fri Aug 23, 2024 2:51 pm
An 18 motor has no provision to mount a generator.
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Fri Aug 23, 2024 4:41 pm
Gee, I'm not going to argue with it. There is no discernable serial number but the casting numbers sure look like it says 18. Is this wrong?
Paul
Post by speedytinc » Fri Aug 23, 2024 4:57 pm
I see an opening, like a 9.
5-8-19. May 8, 1919
Post by RajoRacer » Fri Aug 23, 2024 5:20 pm
Post a photo of the carburetor side - easy enough to verify a starter block OR not !
Last Name: House
Post by George House » Fri Aug 23, 2024 5:41 pm
Wow! May 8, 1919. Exactly 74 years to the day before I got married. And I turned 74 last Sunday. Serendipity!!
Last Name: Wrenn
Post by TWrenn » Fri Aug 23, 2024 5:43 pm
5-8-19. May 8, 1919
Yep. Almost clear as a bell actually!
Hudson29
First Name: Paul
Last Name: O'Neil
Post by Hudson29 » Fri Aug 23, 2024 6:57 pm
I could be a 9, but if so, its a poorly designed 9. The car has a generator. Too bad there is no serial number that I can make out.
No matter to the issue on this thread, do these new VRs need an ammeter to set them up? If so, how is done with no installed ammeter?
Paul
Post by speedytinc » Fri Aug 23, 2024 7:15 pm
Paul
You use an analog ammeter between the cutout & the in/out yellow power wire that runs to it.
Which is typically more accurate than the OEM style on the switch plate.
AdminJeff
Post by AdminJeff » Sat Aug 31, 2024 6:13 am
Paul
It is highly advised to use an ammeter. Otherwise, how do you know if your charging system is working? And you need to be able to set your charge rate on the generator. So, its a worthwhile investment. I have an extra original ammeter I could part with if you need one.
Jeff
Post by Allan » Sat Aug 31, 2024 6:52 am
From the photo of the block it would appear that the original engine number has been machined off. The mating surface of the side outlet appears proud of the engine number boss, rather than on the same plane as usual. Neat work to do the machining around the side outlet.
Post by TRDxB2 » Sat Aug 31, 2024 10:26 am
A closer look
