Cast iron drums Rocky Mountain brakes
Tstroker89
First Name: Michael
Last Name: McDonald
* REQUIRED* Type and Year of Model Ts owned: 3
Post by Tstroker89 » Thu Sep 05, 2024 11:23 pm
I bought a set of new Rocky Mountain brakes with cast iron drums and didn’t have instructions to explain on how to set up the drum with the hub. They are for large drum brakes with wire wheels. I’m having an issue with figuring out how to set up drum with the hub. There is about a 1 inch spacer that came with the kit that I’m not 100 % where is goes. I can post pictures if it will help.
Thank you.
Mark Chaffin
Last Name: Chaffin
Re: Cast iron drums Rocky Mountain brakes
Post by Mark Chaffin » Thu Sep 05, 2024 11:27 pm
Not sure what you bought. The reproduction Rocky Mountain Brakes made by Budd Williams do not come with cast iron drums. Some pictures might help out.
Post by TRDxB2 » Fri Sep 06, 2024 12:16 am
Thank you.
Here you go.
Note in searching there were Original Rockies, First Generation Reproduction Rockies & current reproduction Rockies. These are for the current reproductions courtesy of Snyder's web site. Pictures help a 1 inch spacer can be wide, long, round, square or a part no belonging to the set. It could be for the pedal extension
T-2565-B Rocky Instructions.pdf
(388.9 KiB) Downloaded 110 times
Post by Allan » Fri Sep 06, 2024 4:29 am
Perhaps the cast iron drums are made for a different car. That may mean that the centre hole is larger than that in a T hub, and the spacer is just a device to adapt the T hub to the larger hole in the cast iron drum. Pictures would help.
Tstroker89
First Name: Michael
Last Name: McDonald
Post by Tstroker89 » Fri Sep 06, 2024 8:01 am
The holes line up perfectly for a t wire wheel. I had it mocked up last night. This set is very old, one of the first productions of Rocky Mountain brakes.
Post by speedytinc » Fri Sep 06, 2024 8:05 am
Earlier R/M brake drums were cast iron. Superior product.
The repos I have had were/are dimensionally the same in regards to the brake surfaces.
I believe they were much more expensive to make & therefore discontinued for the stamped ones.
Tstroker89
First Name: Michael
Last Name: McDonald
Post by Tstroker89 » Fri Sep 06, 2024 8:06 am
I tried to add pictures but it’s saying they are to big. Any suggestions?
Last Name: Wrenn
Post by TWrenn » Fri Sep 06, 2024 8:17 am
If they're one of the first, that'll certainly excite Original Smith!! :lol:
Post by speedytinc » Fri Sep 06, 2024 8:34 am
Being setup for wire wheels is a wonder. (26-7 ?)
I have not seen that before.
jsaylor
Last Name: Saylor
Post by jsaylor » Fri Sep 06, 2024 12:03 pm
"I tried to add pictures but it’s saying they are to big. Any suggestions?"
To Resize the photos. Open the photo with MS Paint, click pixels, resize to 900. Save. Should then post ok.
RVA23T
Last Name: C
Post by RVA23T » Fri Sep 06, 2024 1:54 pm
Sent you an email with my contact info so you can send them to me if you can't resize the & I will post for you.
Post by Original Smith » Fri Sep 06, 2024 2:12 pm
People with accessory brakes call them Rocky Mountain, which is not correct. Only real Rocky Mountain brakes are the real thing. Rocky Mountain did use a steel drum originally that was riveted to an original Ford drum. I pays to know what you are talking about!
kmatt2
First Name: Kevin
Last Name: Matthiesen
Post by kmatt2 » Fri Sep 06, 2024 3:38 pm
Back in the late 1970’s the reproduction Rocky Mt Brakes came with larger cast iron drums that also had the smaller 8 inch T drum cast in. These cast drums were drilled to use T wood wheel rear hubs that fit a counter bore in the cast drum. The brake bans for these brakes had a rear anchor and worked much better in reverse than the current type small drum reproduction brakes. At the time these brakes were being sold I had a speedster that had a small drum Ruckstell , but I used 1926-27 T wire wheels. I was able to buy my Rocky Mt Brakes with the cast drums not drilled and then had the cast drums drilled for five lug 1926-27 wire wheels. At the time this worked great, perhaps someone else also did this and that is where your cast brake drums came from.
kmatt2
First Name: Kevin
Post by kmatt2 » Fri Sep 06, 2024 3:39 pm
Sorry for double post. How I dislike posting here I thought they fixed the double post problem but didn’t get the warning this time.
RVA23T
Last Name: C
Post by RVA23T » Fri Sep 06, 2024 6:03 pm
Tstroker89's Pictures attached
kmatt2
First Name: Kevin
Post by kmatt2 » Fri Sep 06, 2024 6:26 pm
Those new pictures show cast iron brake drums that are quite different from the 1970’s Rocky Mt Brake cast iron drums that I had. Perhaps if you post a picture of the brake bands or brake shoes that came with the drums it would help to identify them.
Post by RajoRacer » Fri Sep 06, 2024 6:28 pm
I've seen a lot of accessory brake types & drums but that's a new one on me ! I have a couple sets of Sunderman repros that included a cast iron double drum.
Post by Mark Gregush » Fri Sep 06, 2024 10:17 pm
What is the bolt pattern on these drums? Looks larger than 5X5. Was the outside finished as well?
Tstroker89
First Name: Michael
Last Name: McDonald
Post by Tstroker89 » Sat Sep 07, 2024 12:14 pm
The bolt pattern is the same for a t wire wheel. There will be a picture of the wheel bolted on with the spacer.
RVA23T
Last Name: C
Post by RVA23T » Sat Sep 07, 2024 12:59 pm
Another Pic
RVA23T
Last Name: C
Post by RVA23T » Sat Sep 07, 2024 6:05 pm
Just like a 26 T, an "improved" picture
Post by Mark Gregush » Sat Sep 07, 2024 9:50 pm
Think I would pass on using that setup. The 26/27 wire wheel needs to be supported by the machined area on the hub at the outer end (the lip that is also used by the hub puller) and press up to the drum not just held on by the lug bolts/nuts. From the photos, looks like the wheels are now moved outboard of where they should be.
Tstroker89
First Name: Michael
Last Name: McDonald
Post by Tstroker89 » Sat Sep 07, 2024 10:50 pm
I plan to still use this setup if I can figure out if the spacer is needed or not. I believe floating rear hubs for wire wheels have a similar setup. I mainly made this post to see if someone else ever used or seen this set up before.
kmatt2
First Name: Kevin
Post by kmatt2 » Sun Sep 08, 2024 12:55 am
OK I think I know how your system is supposed to work, but with out any dimensions I can’t be sure. The red primered adaptor goes inside the cast iron drum with the flat side in contact with the drum fitting against the inner cast drum. Your 1926-27 wire wheel rear hub, sans stock pressed steel drum and wheel studs, goes into the adaptor centering on the adaptors’s machined taper. New wheel studs of unknown length go through everything in this order from the inside, T wire wheel hub, cast iron brake drum adapter, cast iron brake drum. The Model T wire mounts so that the tapered part on the out side of the cast iron drum contacts the inside of the T wire wheel. If I am correct on how this goes together I don’t think you gain anything, if you use the stock 26-27 brake bans. Are you sure that you are not missing some sort of aftermarket brake backing plates for hydraulic brakes ? I have used stock 26-27 wire wheel rear hubs with the AC type external contracting brakes and the stock internal expanding emergency brakes with out any problems.
kmatt2
First Name: Kevin
Post by kmatt2 » Sun Sep 08, 2024 12:57 am
OK I think I know how your system is supposed to work, but with out any dimensions I can’t be sure. The red primered adaptor goes inside the cast iron drum with the flat side in contact with the drum fitting against the inner cast drum. Your 1926-27 wire wheel rear hub, sans stock pressed steel drum and wheel studs, goes into the adaptor centering on the adaptors’s machined taper. New wheel studs of unknown length go through everything in this order from the inside, T wire wheel hub, cast iron brake drum adapter, cast iron brake drum. The Model T wire wheel mounts so that the tapered part on the out side of the cast iron drum contacts the inside of the T wire wheel. If I am correct on how this goes together I don’t think you gain anything, if you use the stock 26-27 brake bans. Are you sure that you are not missing some sort of aftermarket brake backing plates for hydraulic brakes ? I have used stock 26-27 wire wheel rear hubs with the AC type external contracting brakes and the stock internal expanding emergency brakes with out any problems.
kmatt2
First Name: Kevin
Post by kmatt2 » Sun Sep 08, 2024 1:18 am
Post by Allan » Sun Sep 08, 2024 1:49 am
Has the outside surface of the drums been machined? If not, they are likely for a different purpose. As mentioned, T wire wheels need to be supported on the inside edge. Even with this, they were still prone to flexing and cracking between the stud holes. This was cured in the A model wheels by pressing a ridge between the stud holes to stiffen up the hub.
Post by Original Smith » Sun Sep 08, 2024 1:26 pm
I was there when the first series Rocky Mountain Brakes were made by Jack Sunderlin. I have a couple of sets of those drums. They work fine, but were not machined to my liking. There was no radius on the top surface as original, and the area between the inside of the top surface should have been machined too to get rid of the casting marks.
The problem with Jack was he wasn't a gear head! He wrongly assumed that all equalizers are the same, and hence, that is why they have rods instead of cables. When Bud took over the business, I don't understand why he didn't correct the problem, but he didn't. I have done the research, and know exactly what Rocky Mountain used. Too bad someone with a machinist background hasn't come to the rescue!
Tstroker89
First Name: Michael
Last Name: McDonald
Post by Tstroker89 » Sun Sep 08, 2024 4:23 pm
This is great information. What sequence does the drum, hub and spacer go?
