Hood Corners Pads - what are they?
Last Name: Hjortnaes
Post by DHort » Thu Jun 13, 2019 5:27 pm
4054 and 4054B. I see them in the catalog but have never seen them on a car. Are they rarely used?
Rich Bingham
First Name: Rich
Last Name: Bingham
Re: Hood Corners Pads - what are they?
Post by Rich Bingham » Thu Jun 13, 2019 6:00 pm
Little leather triangular "pockets" meant to be riveted to the inside lower corners of the hood, presumably keep the hood from scratching up the cowl. Unnecessary accessory ?
"Get a horse !"
Post by DanTreace » Thu Jun 13, 2019 6:07 pm
The late Improved Car used these pads, factory. You can tell if your late T was installed at the factory as you will find tiny hole at the edge of the hood.
Here is original remains of a factory pad. Think these were late 1926 addition, when the Improved Car got the change to Vaproizer carb, and later with the nickel head bolts....all this 'fancy' stuff that Edsel saw done, as he was practicing for the designs of the NEW Ford to come. ;)
Hood Pad.jpg (120.78 KiB) Viewed 7075 times
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Jun 13, 2019 9:42 pm
Sometimes making your own from scraps of black leather with a simple single stitch is a better alternative. Soak in water for a couple of hours, using a c-clamp with small pieces of wood and wax paper, clamp in place and let sit for a day. Remove and let dry, then reinstall with a little black weatherstripping adhesive. Looks Good!
All the Best,
Hank in Tin-A-See
blgitn
First Name: Roger
Last Name: Harmon
Post by blgitn » Fri Jun 14, 2019 9:00 pm
Very nice!
dunoon
Last Name: Davis
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by dunoon » Sat Jun 15, 2019 9:34 am
Hank, How did you get that corner pad to mold to the hood?
Rich USN Ret in Va.
dlmyers
First Name: Dale
Last Name: Myers
Post by dlmyers » Sat Jun 15, 2019 10:28 am
They would come in handy to prevent this.
The old forums are a gold mine of information.
Post by John kuehn » Sat Jun 15, 2019 5:55 pm
After a Model T got older and was still a good serviceable car items like engine pans, hood pad corners, door straps and a few other items that were considered unnecessary items were discarded. Or at least the remains of T’s that were still fairly complete that I’ve seen over the years. Don’t see many around in this area any more. Maybe frame remains but that’s about it.
Doug Keppler
First Name: Douglas
Last Name: Keppler
Post by Doug Keppler » Sat Jun 15, 2019 6:08 pm
Richard, read what he wrote it explains how he had them formed to the hood
1924 Touring car
There's No Substitute for Proper Lubrication
JimKelsey
First Name: Jim
Last Name: Kelsey
* REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Tudor
Board Member Since: 2010
Post by JimKelsey » Sat Jun 15, 2019 10:35 pm
They are great to have as they keep a klutzy guy, like myself, from scratching the cowl.
Post by DHort » Sat Jun 15, 2019 10:47 pm
Doug. The directions make no sense to me either. Soak in water with c clamp, bits of wood, and wax paper. Apply with a little bit of adhesive. I dont see how that would make them look as good as they do. Hank did a great job.
Doug Keppler
First Name: Douglas
Last Name: Keppler
Post by Doug Keppler » Sun Jun 16, 2019 7:14 am
Soak in water for about 4 hours clamp them while they're still wet, let them dry in clamped position, remove and use weathestrip adhesive to apply them to the hood
1924 Touring car
