Today’s project
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Today’s project
Post by D.Yoder » Thu Jun 13, 2019 3:04 pm
Randall strickland
First Name: Randall
Last Name: Strickland
Re: Today’s project
Post by Randall strickland » Thu Jun 13, 2019 10:15 pm
I like your depth gauge! I have a couple I need to do
Dennis_Brown
Last Name: Brown
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Re: Today’s project
Post by Dennis_Brown » Thu Jun 13, 2019 10:39 pm
I am trying to figure out what you are repairing.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Today’s project
Post by D.Yoder » Thu Jun 13, 2019 11:31 pm
Wish bone ball socket.
Ball socket
Ball socket
Adam
First Name: Adam
Last Name: Doleshal
Re: Today’s project
Post by Adam » Fri Jun 14, 2019 8:26 am
Turn the speed way down. Maybe 200 rpm. Then it will look like this:
Mark Nunn
Last Name: Nunn
Re: Today’s project
Post by Mark Nunn » Fri Jun 14, 2019 8:41 am
Can you explain how you built up the material around the socket? Weld, braze, other method? I need to find a way to fix this.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Today’s project
Post by D.Yoder » Fri Jun 14, 2019 9:00 pm
I use a wire welder.
25 roadster john
Last Name: Pawlowski
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Re: Today’s project
Post by 25 roadster john » Fri Jun 14, 2019 9:09 pm
Hello all,
My question is what do you use to form the socket?
Is this something that can be done in a drill press? :shock:
BobShirleyAtlantaTx
First Name: Bob
Last Name: Shirley
Re: Today’s project
Post by BobShirleyAtlantaTx » Sat Jun 15, 2019 12:20 am
I’m with John, please post a picture of your cutter, the model number and where to purchase. Thanks
Last Name: Hatch
Re: Today’s project
Post by Dan Hatch » Sat Jun 15, 2019 7:32 am
Tool is called ball end mill.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Today’s project
Post by D.Yoder » Sat Jun 15, 2019 12:44 pm
RGould1910
Last Name: Gould
Re: Today’s project
Post by RGould1910 » Sat Jun 15, 2019 1:16 pm
An 1 1/4 " ball mill requires a lot of pressure to cut weld. I can't see how a drill press would work. I did the same thing using a tig welder and silicon carbide with a 1910 pan and the pressure warped the pan on a mill. I like the idea of brazing the hole. Not so tough to cut
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Today’s project
Post by D.Yoder » Sat Jun 15, 2019 8:21 pm
Richard, You need to drill a 3/8 inch pilot hole before you use the end mill. Doesn’t require as much pressure.
