Brake light switch mounting
Jmeredith
Topic author - Posts: 45
- First Name: Jesse
- Last Name: MEREDITH
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Can someone provide a picture or instructions on mounting this switch I just purchased from Langs. I can’t seem to place it correctly. [image][/image]
This on a 26 coupe.
This on a 26 coupe.
- First Name: Austin
- Last Name: Farmer
Re: Brake light switch mounting
Did it come with any information sheet or anything?
Usually lang's is good with including an instruction sheet with the things i've bought.
Maybe call them on Monday morning?
Jmeredith
- First Name: Jesse
No, nothing came with it. I will call them if I can’t get anything by Monday.
Dan McEachern
- First Name: DAN
- Last Name: MCEACHERN
Appears to mount on the LH frame rail with the switch end pointing toward the brake pedal shaft. The cam action of the pedal moves the end of it toward the switch plunger.
- Last Name: Strange
Dan is correct. From Lang's website listing on the item: " This switch mounts on the frame next to the brake pedal and lines up with the shaft going into the hogs head. As you press down on the pedal it also moves left due to the cam on the out side. This left movement activates the switch."
https://www.modeltford.com/item/3158FM.aspx
This is my install on that type brake light switch, works swell too.
- Attachments
- IMG_2337 (600x450) (580x435) (570x428) copy.jpeg (92.03 KiB) Viewed 2815 times
Oh for John Regan's switch!! I thank God I got both my cars feexed with them and a couple I don't even own anymore!! At least others benefit from it!
Jmeredith
- First Name: Jesse
Thanks guys. I will take a look at it tomorrow. Does this require a hole being drilled in the frame?
No. It clamps on the frame rail by those 2 bolts.
Here what the say. Looks like a bit of trial & error to get it to depress
RecklessKelly
- Last Name: Maxson
The top plate goes over the frame rail and the lower plate nests inside of the rail to constrain the unit. I would heat shrink the terminations, I went to adjust mine and turned the switch by accident, shorting out the terminal to the unit and blowing the bulb.
babychadwick
- First Name: Chad
- Last Name: Azevedo
The best setup I have seen for a brake light switch is to us a momentary off (off when the button is pressed) combined with the earlier flat inspection cover. I believe an 80's GM switch is a good source. Mounting is done on the hoggshead where the switch is depressed when the pedal is all the way back. Once the pedal is moved the switch button is released and the light comes on. It doesn't matter if the pedal is depressed 1 inch or to the floorboards, the brake comes on. Unlike other systems that rely on a button to be depressed or closed once the pedal activates which must be compensated with a spring or become a stop for the pedal.
