Brake light switch mounting
Jmeredith
First Name: Jesse
Last Name: MEREDITH
* REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Post by Jmeredith » Sun Sep 22, 2024 12:21 pm
Can someone provide a picture or instructions on mounting this switch I just purchased from Langs. I can’t seem to place it correctly. [image]
[/image]
This on a 26 coupe.
First Name: Austin
Last Name: Farmer
Re: Brake light switch mounting
Post by 1925 Touring » Sun Sep 22, 2024 12:41 pm
Did it come with any information sheet or anything?
Usually lang's is good with including an instruction sheet with the things i've bought.
Maybe call them on Monday morning?
Jmeredith
First Name: Jesse
Last Name: MEREDITH
Post by Jmeredith » Sun Sep 22, 2024 12:53 pm
No, nothing came with it. I will call them if I can’t get anything by Monday.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Sep 22, 2024 1:19 pm
Appears to mount on the LH frame rail with the switch end pointing toward the brake pedal shaft. The cam action of the pedal moves the end of it toward the switch plunger.
Last Name: Strange
Post by CudaMan » Sun Sep 22, 2024 1:50 pm
Dan is correct. From Lang's website listing on the item: " This switch mounts on the frame next to the brake pedal and lines up with the shaft going into the hogs head. As you press down on the pedal it also moves left due to the cam on the out side. This left movement activates the switch."
https://www.modeltford.com/item/3158FM.aspx
Post by DanTreace » Sun Sep 22, 2024 2:40 pm
This is my install on that type brake light switch, works swell too.
IMG_2337 (600x450) (580x435) (570x428) copy.jpeg (92.03 KiB) Viewed 2841 times
Last Name: Wrenn
Post by TWrenn » Sun Sep 22, 2024 2:43 pm
Oh for John Regan's switch!! I thank God I got both my cars feexed with them and a couple I don't even own anymore!! At least others benefit from it!
Jmeredith
First Name: Jesse
Last Name: MEREDITH
Post by Jmeredith » Sun Sep 22, 2024 5:19 pm
Thanks guys. I will take a look at it tomorrow. Does this require a hole being drilled in the frame?
Post by speedytinc » Sun Sep 22, 2024 5:38 pm
No. It clamps on the frame rail by those 2 bolts.
Post by TRDxB2 » Sun Sep 22, 2024 5:38 pm
Here what the say. Looks like a bit of trial & error to get it to depress
RecklessKelly
Last Name: Maxson
Post by RecklessKelly » Mon Sep 23, 2024 8:56 am
The top plate goes over the frame rail and the lower plate nests inside of the rail to constrain the unit. I would heat shrink the terminations, I went to adjust mine and turned the switch by accident, shorting out the terminal to the unit and blowing the bulb.
babychadwick
First Name: Chad
Last Name: Azevedo
Post by babychadwick » Wed Sep 25, 2024 7:27 am
The best setup I have seen for a brake light switch is to us a momentary off (off when the button is pressed) combined with the earlier flat inspection cover. I believe an 80's GM switch is a good source. Mounting is done on the hoggshead where the switch is depressed when the pedal is all the way back. Once the pedal is moved the switch button is released and the light comes on. It doesn't matter if the pedal is depressed 1 inch or to the floorboards, the brake comes on. Unlike other systems that rely on a button to be depressed or closed once the pedal activates which must be compensated with a spring or become a stop for the pedal.
