recommendation on 6 volt battery purchase
Dave_Kriegel
Topic author - Posts: 74
- First Name: David
- Last Name: Kriegel
- * REQUIRED* Type and Year of Model Ts owned: 1927 1926
It appears the size I need is 19L? but finding one? I will try tractor supply stores tomorrow but any suggestions please I did a battery forum search lots of info on battery carriers and 12 volt but could not find a recommendation on a good 6 volt battery
Ed Baudoux
- First Name: Edward
- Last Name: Baudoux
Re: recommendation on 6 volt battery purchase
I have had very good results with Napa 6 volt batteries. My last one lasted 12 years.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
Les Schubert
- First Name: Les
- Last Name: Schubert
I buy a Group 1 tractor battery at Peavey Mart.
25 roadster john
- Last Name: Pawlowski
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
Tractor supply have them in stock. At least at my local store. Remember to check the date of manufacture. Make sure you get the freshest battery.
Some Auto Zone stores carry them. The one here in El Cajon Ca has fresh ones. There should be a sticker on the battery with a date. Try to find one with a recent date. It will last longer. Group 1 6 volts. I have also ordered them from Napa. Those need to be ordered in advance. Takes a day or 2 to receive it at the store. It is the same battery as a standard Model A battery and some of the Chrysler cars in the 30's so not rare.
I bought one recently at Auto Zone. It would really help if you would tell us what you are using it in!
Ruxstel24
- Last Name: Hanlon
I bought my last one about 3-4 years ago from Federated. Deka I believe. Still going strong.
Fleet & Farm, TSC, Orscheln — whatever the local farm supply is. Don't let some kid tell you they're only for tractors.
- Last Name: Hjortnaes
I sprung for an optima sealed battery. No extra charging. No hydrogen. No worries.
I should have asked what year we're discussing. A pre-starter car doesn't require a big expensive battery.
Gonenorth
- First Name: Kevin
- Last Name: Whelihan
- Board Member Since: 2008
Looks like a standard tractor battery. I have never gotten any more than three years out of them. Cells seem prone to shorting out. Paid up for a Optima Red Top 6 volt sealed battery. End of issues. And at 850 CCA as opposed to most other farm batteries 600 CCA, it rolls the engine over faster and it starts easier. No leaks either as it is sealed.
KirkieP
- First Name: Kirk
- Last Name: Peterson
- * REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
I purchased my last one at Big R. I started using a battery maintainer. It appears that has increased its life span for me.
Kirk Peterson
Santa Fe NM
Santa Fe NM
If your looking for a T 6v battery buy a 6v group 1 battery. Common in older tractors, old cars and Model T’s. Get one at Auto-Zone, farm supply stores such as Tractor Supply and other related stores.
- Last Name: Wrenn
His profile says he has a '21..Steve Jelf wrote: ↑Sat Jun 15, 2019 1:03 amI should have asked what year we're discussing. A pre-starter car doesn't require a big expensive battery.
Les Schubert
- First Name: Les
I have usually gotten 10 years use. Typically have to add some DISTILLED water after a few years use
On my 13 I have a Seadoo battery tucked in by the end of the gas tank. I charge it off the magneto. I am running a Tru-fire in a Heinz box
Dave_Kriegel
- First Name: David
Thank you all for the great advice especially on group one size This is for a 1925 starter car I am repairing for a friend
I started a response earlier and saved the draft - but looks like I need to start over
Eckler's used to sell a repro 6 volt FORD battery whose dimensions were 9-1/4" long x 7-3/8" wide x 9" high. Height is measured to Top of posts & 550 cold cranking amps. I some further searching and found that the BCI (Battery Council International) Group Size is 1. This battery size will best fit the physical dimensions, terminal locations and type required for your vehicle. A 19L may be too big to fit in the space available. Check it out
There are many 6 volt batteries available and group sizes, but the first thing to determine is what physical size do you need. While cold crank power is important another factor is charging. There are 6 volt "golf cart" batteries that are designed to withstand deep recharging. I came across some explanation of the common types available. AGM stands out as it is more resistant to vibrations and may be a good choice if you have a voltage regulator.
Flooded lead acid batteries are the most common type of battery you’ll find on the market. They’re versatile in terms of design and use. They come in a number of sizes and aren’t sealed. This means that you can replenish any lost electrolyte. These batteries have lead plates based on sulphuric acid.
Gel lead acid batteries utilize a thickening agent to keep the electrolyte still. It can’t move freely. This is great if you ride rough. If your battery gets cracked, it’ll still run smoothly. The one downside is that it’s completely sealed.
AGM lead acid batteries are relatively new. These batteries use a fiberglass separator to keep the electrolyte in place. AGM batteries are considered to be one of the most robust battery options because they’re spill-proof, resistant to vibrations, and hold up well to impacts.
Just one more thing -- Blain's Farm & Fleet $59.99 after $10 exchange Dimensions:9" X 6-7/8" X 8-3/4" Group Size: 1 Power: 640 CCA
