bolt source for fly wheel start ring
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Mon Sep 30, 2024 9:28 am
I am setting up an engine to be run without a magneto. any idea where i can obtain 1/4 x 24 bolts to attach the starter ring ?
Last Name: Hatch
Re: bolt source for fly wheel start ring
Post by Dan Hatch » Mon Sep 30, 2024 10:04 am
For my money Dan M on here has the best slinger and bolt kit.
He also makes a ring to keep triple gear pins from backing out.
I will not remove magnets for customer without one of those kits.
johnr
Post by johnr » Mon Sep 30, 2024 12:20 pm
Thank you for the reply. I already have the retaining ring and slingers made. looking for a source for the bolts to attach the starter ring.
big2bird
First Name: Jeffrey
Last Name: Hausey
Post by big2bird » Mon Sep 30, 2024 12:21 pm
Try Mc Master Carr.
Post by speedytinc » Mon Sep 30, 2024 12:34 pm
6mm hex head.
I have done many conversions using metric bolts.
First Name: craig
Last Name: leach
Post by Craig Leach » Mon Sep 30, 2024 1:24 pm
Hi John,
The 6mm will self lock in the threads so make sure the length is correct to tighten the ring gear.
Post by speedytinc » Mon Sep 30, 2024 1:33 pm
I Get the length to stick out 1/6" additional & peen the ends.
I use lock washers also. That & the self locking nature of the close thread makes for a triple safe install.
Never had one come loose.
P.S. These bolts are for the original 14-24 thread. I have no experience with the current incorrectly threaded 1/4-24 ring gears.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Mon Sep 30, 2024 1:41 pm
You can also retap the ring gear 1/4-28 and it will work just fine. As John mentioned you can also tap to a 6mm thread. Not sure I would just force the 6mm thread in to the ring gear.
ModelTWoods
First Name: Terry
Last Name: Woods
Post by ModelTWoods » Mon Sep 30, 2024 3:06 pm
Is this an item the vendors do NOT stock?
