Attachment on inside firewall
CoombsCars
Topic author - Posts: 9
- First Name: Bobby
- Last Name: Coombs
- * REQUIRED* Type and Year of Model Ts owned: 1927 T Wrecker
Hello All, I am new to the T Model world and have enjoyed learning a lot from information found within your forums - thank you very much. I hope that someone can tell me what the green bottle attached to the inner firewall just above the ID plate and to the left of the oil can as seen in this photo. Its a poor picture so I can add another in the near future if needed. The item is a glass bowl with a metal top but has no wires nor hoses attached.
Thanks in advance!
Re: Attachment on inside firewall
Yes, close-ups from different angles would be better. My first impulse is to say aftermarket accessory, but a closer look might help to ID what it is.
Rich P. Bingham
- First Name: Rich
- Last Name: Bingham
It’s a flower vase. Why on one pillar of an open cab ? Anyone’s guess. Well into the 30’s, it was common to find a pair of bud vases inside closed cars. A touch of class !
Get a horse !
- Last Name: Tannehill
- Board Member Since: 2002
Looks like you have a depot hack. Is the piece in question on a swivel? If the cap has a clip holding it on it could be an ashtray but honestly don’t know. Best John
Appears to have an electrical wire running to the top of that round thing, might be some type of bell or signal device.
Need a better photo of that device.
jiminbartow
- Last Name: Patrick
Get down to floor level and take a picture straight on using the flash. Most of the mystery is blocked by the dash.
There are normally a pair of flower vases attached to the columns directly behind the front doors.
Tadpole
- First Name: Tad
- Last Name: Glahn
Without a better look at it, I think it's one of these glass ashtrays.
Moxie26
- First Name: Robert
- Last Name: Jablonski
Tad .... You have a "good eye" for period accessories
CoombsCars
- First Name: Bobby
- Last Name: Coombs
That is exactly it, amazing! Thank you. This is a 27 Wrecker that's been in the family for about 45years and I'm bringing it back to life. It has several "oddities" becaause for the life of me I don't understand why it has a Bud Vase and now a ashtray when it doesn't even have doors! Naturally over the course of almost 100 years I'm sure that others applied their on ideas of what it needed.
You guys re wonderful, thank again for the help!
I don’t think the bud vase came with your T wrecker but was added along with the ash tray. As time goes on when learning about Model T’s you will find that there were LOTS of add ons and accessories that came out from the aftermarket folks. It’s great thats you’ve got a T to learn and work on. Good luck with your car and welcome to the T world!
Wingnut
- First Name: William
- Last Name: Reep
- * REQUIRED* Type and Year of Model Ts owned: 1924 roadster, 1926touring, 1926 Coupe
I would've thought it was for bootleg whiskey, sounds good anyway.
AhAhh that's the answer!!!!!Rich P. Bingham wrote: ↑Thu Oct 03, 2024 11:24 amIt’s a flower vase. Why on one pillar of an open cab ? Anyone’s guess. Well into the 30’s, it was common to find a pair of bud vases inside closed cars. A touch of class !
Since its a glass bowl with a metal top but has no wires nor hoses attached.
Its to hold water for watering the flowers in the bud vase!!!
Tadpole
- First Name: Tad
- Last Name: Glahn
Thank you Moxie-Man! Glad I guessed right, enjoy your wrecker project!
