Switch repair
Gary Gregory
First Name: Gary
Last Name: Gregory
* REQUIRED* Type and Year of Model Ts owned: 1927 Model T Roadster
Switch repair
Post by Gary Gregory » Sat Jun 15, 2019 9:45 pm
What do you guys use to attach the switch onto the switch plate ? This one had small rusty screws which I know isn't correct. Came off my 27 Roadster.
Re: Switch repair
Post by RajoRacer » Sat Jun 15, 2019 10:42 pm
Exact copy of the original rivets I have.
Gary Gregory
First Name: Gary
Last Name: Gregory
Re: Switch repair
Post by Gary Gregory » Sat Jun 15, 2019 10:49 pm
RajoRacer where could I get a set ?
Re: Switch repair
Post by Mark Gregush » Sat Jun 15, 2019 11:29 pm
I don't think the original rivet will work, the holes have been drilled out to larger size for the screws. As I recall that rivet is about 1/8" approx (may be a bit smaller then that).
Re: Switch repair
Post by Original Smith » Sun Jun 16, 2019 10:07 am
It depends on how much of a purist you are. I would discard the plate you have, and find another. The appearance of the rivets for that switch plate are important, and it wouldn't look right to have screws or oversize rivets.
Re: Switch repair
Post by RajoRacer » Sun Jun 16, 2019 11:35 am
Send me an email - I'll throw a pair in an envelope. These were machined by Otis Clinton - Larry knew him well !
