Low band adjustment very stiff
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Wed Oct 16, 2024 5:05 pm
It takes a big crescent wrench and a cheater bar to turn my low band adjustment after the jam nut is loosened. Are there any thoughts on why this could be and if I'm potentially doing damage with the "strong arm" approach? As always, many thanks for your input.
Re: Low band adjustment very stiff
Post by Jerry VanOoteghem » Wed Oct 16, 2024 5:23 pm
Forcing something like that seldom improves it. It will only get worse. While you can still move it at all, I'd remove the adjuster and inspect the threads on it and in the hogshead.
Post by speedytinc » Wed Oct 16, 2024 5:27 pm
First thought is buggered/stripped threads.
Pull the inspection cover. Pry the band tight with a big screwdriver. Does the adjuster now easily turn? That eliminates a bind in the adjuster & band ear. If still stiff, figure its a thread issue. Look @ the adjuster for buggered threads. Remove & clean as necessary.
Other than a rusted up HH, I have not encountered your problem. In an in service T, the adjuster turns about finger pressure after the jam nut is loose.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Post by JohnM » Wed Oct 16, 2024 5:38 pm
As Jerry said, make sure it is not cross threaded. The jam nut needs to be backed off more than just loose, otherwise a couple turns of the adjuster and it will jam again. Next I would take the inspection cover off and look at what is going on inside.
Post by John kuehn » Wed Oct 16, 2024 6:25 pm
If it’s that hard to turn and with a cheater bar it sounds like it’s crossed threaded. If it’s that hard it would be best to remove the adjuster and find the correct tap and hopefully it can be rethreaded. Maybe someone knows on the forum knows what the correct size tap it would be. That’s the very first thing that needs to be done when the adjuster is taken out.
You can use a battery holder wire brush that’s round to clean out the transmission cover hole or any round treaded hole. It works pretty good for that purpose.
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Wed Oct 16, 2024 8:29 pm
Thank you everybody. Your responses are in line with my thinking. Soon I will be putting her up for the winter and I'll get into it. I just wanted to pick your brains and see if there was something I was overlooking. You all are the best!! Happy holidays.
Ken Buhler
First Name: Ken
Last Name: Buhler
Board Member Since: 2012
Post by Ken Buhler » Wed Oct 16, 2024 10:38 pm
Acetone and ATF mix is the best penetrating oil. Soak well in advance then only 'crack' the thread wet, wiggle back and forth adding juice and feel the length of the loose stroke getting longer. Patience.
Work honestly
Stay true to your word
Get the job done right
Gracie'sDad
Last Name: Dow
Post by Gracie'sDad » Thu Oct 17, 2024 10:42 am
Good idea Ken, your suggestion sure won't hurt. I didn't think of using a penetrating oil due to the fact the threads are "wet" on the inside. Many thanks!!
