Wanted Info. On Simmons Carb.
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Post by Plankhill » Thu Oct 17, 2024 11:33 am
Does anyone have a copy of the original instructions for the Simmons, Wizard, Duplex type carburetors. What I am looking for are the recommendations for wiring the heating element.
Re: Wanted Info. On Simmons Carb.
Post by Mark Gregush » Thu Oct 17, 2024 1:28 pm
The recommendation would be not to wire it up and to remove the coil completely and plug the hole. Gas today is far more volatile than what was sold back then.
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Thu Oct 17, 2024 1:42 pm
That heater element has started a lot of fires and made the Simmons Carb very unpopular.
You can just attach 6 Volts to the terminal and watch for smoke when the carb is not on the manifold.
Russ Potter restored the ones I have and he removes the element and connection, then screws a small Allen head screw in there and pounds over the threads, so they can't come out.
Actually, it would not do any damage if it was left in and never connected.
Post by Jerry VanOoteghem » Thu Oct 17, 2024 2:25 pm
It may not do any damage, but I can imagine the vaporized fuel hitting it, then recondensing into droplets.
Post by DanTreace » Thu Oct 17, 2024 2:49 pm
Photo courtesy of Corey Walker.
Drawing from the MTFCA Forum Gallery
Post by Wayne Sheldon » Thu Oct 17, 2024 5:58 pm
Remove the coil or leave it alone! Your choice, but removing it may be the wiser decision. DO NOT CONNECT power to the coil!
J1MGOLDEN
Last Name: Golden
Post by J1MGOLDEN » Fri Oct 18, 2024 7:57 am
Someone did for Dan's photo.
There is no smoke or fire.
Post by DanTreace » Fri Oct 18, 2024 8:50 am
Jim
That Simmons is a test photo, was away from any gasoline, and wasn’t mounted under the hood ;)
I’ll be wary of one with hot coil on a T
Plankhill
First Name: Brendan
Last Name: Doughty
Post by Plankhill » Fri Oct 18, 2024 9:17 am
The coil is for improving cold weather starting. Back to the real question. Does anyone have the original instructions.
Post by DanTreace » Fri Oct 18, 2024 9:44 am
Brendan
Wiring would be simple to the coil terminal. Run wire from + terminal to an on-off toggle or push-pull switch. Then from switch to the Simmons coil terminal. Switch on to energize the coil for heat prior to starting. After engine warms, switch off the coil.
Purpose was to preheat the old time gas to help starts.
Wiring diagram similar to heated steering wheel wraps, sketch shows AC magneto for +, but storage DC battery is best.
Corey Walker
First Name: Corey
Last Name: Walker
Post by Corey Walker » Fri Oct 18, 2024 11:22 am
I’m not sure I’d use the element, I just wanted to try it out. When you remove it the hole is already the right size for a 10-32 tap and then I put a screw there to plug the hole.
mbowen
First Name: Miles
Last Name: Bowen
Post by mbowen » Fri Oct 18, 2024 11:55 am
I too would like to see instructions. I have what I’m told is a Simmons carburetor on my ‘24 touring and it runs MIUCH better than either of the two NH’s I have. It gives easy cold starts and consistently gives me 20-21 mpg on tour. The only issue I’ve ever had was that the “low idle flap” stuck closed once, but a healthy squirt of brake cleaner a little light oil solved that problem. I don’t recall for sure whether or not the heater coil is still there, but it’s not been wired up since I’ve had the car.
Miles
1924 Touring “Bonnie”
1925 Express Wagon “Clyde”
VowellArt
First Name: Martynn
Last Name: Vowell
Board Member Since: 2012
Post by VowellArt » Fri Oct 18, 2024 10:21 pm
From what I've been told from people who have (or had) one, the heating element pre-warms the Throttle side of the Carburetor and Manifold and is on a button, not a switch for momentary use. You're only supposed to hold the button for a few seconds only. It's supposed to help start a cold or iced over car. And apparently it works.
I have one myself, but it is lacking the heating element, but I know basically how to make one and know how to use it, but since I don't live anyplace where my car is likely to be that bloody cold, I don't see the necessity to make and install that heating element.
Fun never quits!
Post by DanTreace » Fri Oct 18, 2024 11:05 pm
Simmons adv. in parts catalog 1924
