‘26 Roadster Body Length / Width?
schwabd1
Topic author - Posts: 282
- Last Name: Schwab
There seems to be a shortage of open trailers in my area to rent, U-Haul wants me to rent an enclosed one instead. Not counting the fenders, running boards, slash aprons, top irons or hood, what is the length and width of a ‘26 roadster body. Just the “tub” and turtle deck? The door opening on the trailers are several inches narrower than the interior width. How wide of a door do I need?
J1MGOLDEN
- Last Name: Golden
Re: ‘26 Roadster Body Length / Width?
All the Model Ts are 12 foot long and 5 foot wide.
I found a lawn mower/tractor trailer with thee ramps in Pittsburg
The flat deck was 6 X 16 feet and it works fine.
J1MGOLDEN
- Last Name: Golden
Make the size 6 X 12.
TMiller6
- First Name: Thomas
- Last Name: Miller
I’m not near my shop right now to measure mine, but I can tell you the body easily fits inside my Econoline. The rear door opening is around 50”.
Tom Miller
Eric Sole
- First Name: Eric
- Last Name: Sole
- * REQUIRED* Type and Year of Model Ts owned: 1927 Roadster
It sounds like you're transporting just the body like I had to do with my 27 Roadster after it was painted.
The body is 47" wide (no top mounting hardware installed) and is aproximately 92" long.
Mine ALMOST fit in a Nissan Vanette, but I had the top mounting studs screwed in and that was too wide.
Best of luck!
Best of luck!
Eric Sole
- First Name: Eric
- Last Name: Sole
If you're transporting the turtle deck separately, it's about 42" long.
kmatt2
- Last Name: Matthiesen
Back in 1992 I brought back to Fresno Ca from Denver Co a 1926-27 T touring body in the back of a 1987 F150 short bed pickup. I had to leave the tail gate down because of the touring rear curved tub but it fit between the wheel wells ok. I would be concerned that the U-haul closed trailer would not have a big enough door opening width to fit the 1926 roadster body through with out needing to tip the body some.
kmatt2
What type of tow vehicle are you using, if not a pickup ? I think that a standard two axel utility trailer will fit the 1926 roadster body ok. You don’t need a car trailer, I have hauled Model A closed car bodies in two axel utility trailers before.
