Neoprene rear axle seal installation
johnr
Last Name: Delamater
* REQUIRED* Type and Year of Model Ts owned: 1927 Depot Hack
Post by johnr » Mon Nov 04, 2024 10:05 am
I am rebuilding my rear axle of which I am installing new bearings and seals.
I found out that the seal outside diamater is larger than the inside diamater of the outer race requiring
the seal inserted prior to the outer race.
Should I assemble the axle and differential into the housing first.
Next install the seal with metal plate facing outward and then follow up with installing
the outer race.
If I go this route I will machine a pusher up to insert the seal to the bottom of the axle
tube.
Sound about the right way to proceed ?
Re: Neoprene rear axle seal installation
Post by DanTreace » Mon Nov 04, 2024 10:10 am
Yes. You have the process correct. Have used the sleeve puller to place the neoprene seal, just push it in with the outer non button end of the puller. Pre-grease the neoprene seal so it slips on the axle easy.
Then place a radiator gear drive hose clamp around the sleeve to collapse it some for slipping it in , align the bump on the sleeve to the recess in the housing
Post by Norman Kling » Mon Nov 04, 2024 10:47 am
Sometimes the sleeve will not fit all the way in. Check that the bearing will go in all the way and then cut off a small amount of the inside edge of the sleeve till it will slip in to where the dimple fits the hole and the hole mates with the grease cup.
Post by Steve Jelf » Mon Nov 04, 2024 11:50 am
This is long, but it includes installing the new seals:
https://www.youtube.com/watch?v=AfxWPsF4KhQ
johnr
Post by johnr » Mon Nov 04, 2024 12:25 pm
Thank you for the help.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Tue Nov 05, 2024 7:35 am
A piece of appropriately sized PVC pipe is excellent for setting the inner seal. A bit of black RTV on the side that hits the inner axle housing makes for a good seal.
1926 Tudor
Daktarirp
Last Name: Poole
* REQUIRED* Type and Year of Model Ts owned: 1909 Mother-in-Law Roadster, 1911 Torpedo Roadster, 1926 Touring
Post by Daktarirp » Thu Nov 21, 2024 11:04 am
Is there a part number for just the neoprene seal that is fitted to the modern aluminum housing? I have a pair of housings that are intact, but the seals are damaged. Just being cheap, and trying to recycle the housings with new neoprene.
SurfCityGene
First Name: Gene
Last Name: Carrothers
Post by SurfCityGene » Thu Nov 21, 2024 2:33 pm
Rich, YES, you can order new seals from the mfg by size. try search CRC or National seals. Look carefully at the old seal and it may have a part number.
1912 Torpedo Roadster
Daktarirp
Last Name: Poole
Post by Daktarirp » Thu Nov 21, 2024 4:24 pm
Thanks, Gene. I have the rear axle apart at a friend's shop, unfortunately not nearby. I suspected someone has been down this road before and might have a handy dandy part number. Failing that, I will chase the rabbit a bit on my own and post a number if I am successful. I really do appreciate your response. I see you have a '12 Torpedo. My long-legged self loves the extra leg room (I have an '11. It is a sweet runner.
RP
michaelb2296
First Name: Michael
Last Name: Bunner
* REQUIRED* Type and Year of Model Ts owned: 1912 Torpedo Roadster 1917 Smith Form-a-Truck
Post by michaelb2296 » Thu Nov 21, 2024 7:11 pm
OPR 09-27 Neoprene Rear Axle Inner Seals/ Pair/modern
Item #: EK-16-53999-1
Unit Price: $2.99
QTY: 2
Ecklers…. You get two for $3
jwipprecht
First Name: JOHN
Last Name: WIPPRECHT
* REQUIRED* Type and Year of Model Ts owned: 1919 Center Door Sedan
Post by jwipprecht » Wed Sep 24, 2025 10:02 am
The YouTube video above illustrates reassembly. It is fantastic.
Last Name: Hjortnaes
Post by DHort » Wed Sep 24, 2025 3:34 pm
Those Eckler seals are $11.99 on the Eckler website, but I am not sure that is what he is looking for.
Daktarirp
Are you looking to replace the seals on this housing?
ewdysar
First Name: Eric
Last Name: D
Post by ewdysar » Wed Sep 24, 2025 5:25 pm
Daktarirp
Dave,
This conversation ended almost a year ago, until it was resurrected with a random comment. Hopefully Daktarirp figured out his solution back in 2024.
Keep crankin',
Eric
Post by DHort » Thu Sep 25, 2025 11:38 am
I see.
2 posts about the same thing at the same time.
I am so confused. Both are old postings..
Post by Jerry VanOoteghem » Thu Sep 25, 2025 11:47 am
I see.
Still, good advice, nonetheless! :)
