Prime
Re: Prime
Number 9 looks like an early T but the steering is on opposite side and has different front springs. What is it?
- Last Name: House
Re: Prime
Re: Prime
It's a Model S, with accessory elliptic springs. Also, some odd brace across the front of the radiator, probably to give extra support to the front frame cross member, which is notoriously weak and probably unfit for the added load that the accessory spring arrangement places upon it.Norman Kling wrote: ↑Mon Nov 04, 2024 1:29 pmNumber 9 looks like an early T but the steering is on opposite side and has different front springs. What is it?
Jones in Aiken SC
- First Name: Gregory
- Last Name: Jones
- * REQUIRED* Type and Year of Model Ts owned: 1912 Roadster, 1926 Coupe
Re: Prime
Ah, the ole bridge near Montesano, Washington. That's where I grew up and graduated from high school.
cslandry
- First Name: Chris
- Last Name: Landry
- * REQUIRED* Type and Year of Model Ts owned: 1915 Speedster, 1926 Touring, 1923 Depot Hack project
Re: Prime
Elliptical spring conversion https://www.mtfca.com/discus/messages/5 ... 1454409893
Re: Prime
And the T also had accessory elliptical front spring set for those who want the buggy bouncecslandry wrote: ↑Wed Nov 06, 2024 9:08 pmElliptical spring conversion https://www.mtfca.com/discus/messages/5 ... 1454409893
