Bolt on Right Side of Block
RecklessKelly
Topic author - Posts: 304
- Last Name: Maxson
- * REQUIRED* Type and Year of Model Ts owned: 1926 model t coupe
Can someone tell me what this bolt holds down? It is under the generator mounting casting. It looked like it had been leaking oil around the bolt head before I cleaned the area. There is no washer under it. I'm replacing some old leaky gaskets and thought if I could add a crush washer or some rtv behind it to seal it, that's one less leak point. I dont want to loosen it without knowing in case it is holding something inside of the crank case.
AndyClary
- First Name: Andrew
- Last Name: Clary
Re: Bolt on Right Side of Block
Can bearing retainer. If it’s leaking just use a little RTV and reinstall.
Andy
Andy
RecklessKelly
- Last Name: Maxson
Is this the bolt?
- Attachments
- IMG_3580.jpeg (36.31 KiB) Viewed 1229 times
Yes. In fact, you can remove it completely. Just don't turn the engine while it's out. By the way, your timing gear is completely worn out.RecklessKelly wrote: ↑Sat Nov 09, 2024 5:39 pmIf I run it out a quarter inch to clean it and dope it up would it be safe to do?
RecklessKelly
- Last Name: Maxson
Thanks I thought it looked bad. The generator gear pin was really buggered and the gear was loose. Could have caused the wear.
Moxie26
- First Name: Robert
- Last Name: Jablonski
The front cam bearing usually wears faster than the middle bearing or the rear bushing. If in doubt just replace with new babbited bearing shell.
