Installing Chicago auxiliary transmission
Rajo T Speedster
Last Name: Rowe
* REQUIRED* Type and Year of Model Ts owned: 1918 RHD Speedster
Post by Rajo T Speedster » Wed Nov 13, 2024 6:55 am
Hi
Trying to install a Chicago auxiliary transmission in my Speedster and find that it fouls the cross shaft.
Does anyone have any images of an installed transmission showing the crosshaft?
Ed Baudoux
First Name: Edward
Last Name: Baudoux
Re: Installing Chicago auxiliary transmission
Post by Ed Baudoux » Wed Nov 13, 2024 9:30 am
I'm attaching a picture of the auxiliary transmission in our TT. This was built in Bob Scherzer's auto shop class in high school, when I was a student in the late 70's. I believe that the Chicago transmission requires a similar custom brake shaft.
Grayling Michigan
1927 Fordor
1926 Huckster
1923 TT
1930 Fordor
1930 Tudor
walber
First Name: Walt
Last Name: Berdan
Post by walber » Wed Nov 13, 2024 4:06 pm
I cut the cross shaft off and made a bracket that bolts to the back side of the front of the transmission (where it bolts to T transmission).
I added another cross shaft at the rear of the Chicago and put a link between the old and new shafts.
Will try to clean things up a bit and get a photo or two this weekend or early next week.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Wed Nov 13, 2024 5:28 pm
We pretty much did the same thing that Walt describes above.
walber
First Name: Walt
Last Name: Berdan
Post by walber » Wed Nov 13, 2024 7:23 pm
Dan's is exactly the same concept and his bracket looks simpler. Go with his.
Rajo T Speedster
Last Name: Rowe
Post by Rajo T Speedster » Thu Nov 14, 2024 7:57 am
Thanks for all the replies. I will alter my cross shaft to go below the box.
[attachmhttps://www.mtfca.com/phpBB3/download/file.php? ... 01969ent=2]IMG_2738.jpg[/attachment][attachmenhttps://www.mtfca.com/phpBB3/download/file.php? ... 1966967t=3]IMG_2734.jpg[/attachment]
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Post by got10carz » Thu Nov 14, 2024 11:38 am
I don't know if this would work or not. Put in a TT cross shaft. Fab a spacer where it bolts to the frame, this would compensate for the difference in the height of the cam. In my mind it would lower the shaft between 1" and1 1/2".
