Carbureter Settling Bowl
Topic author - Posts: 553
- First Name: Tad
- Last Name: Glahn
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1926 TT Closed Cab, 1924 Runabout
I’m sure I’ve seen one of these before, looked on the forum best I could but couldn’t find one in a post. Does anyone know the history of this little settling bowl that screws into the carbureter? It appears to be made of bronze and maybe has a “D” marking on the side but it’s very faint and could just be my eyes. Is this even for a Ford I wonder?
- First Name: Robert
- Last Name: Jablonski
Re: Carbureter Settling Bowl
No doubt it's one of those aftermarket accessories that different companies sold... Probably has a gas filter screen inside and unscrews from the bottom. So when the fuel is shut off at the tank the sediment and the screen can be cleaned out. Never have seen something like this, doesn't surprise me that someone manufactured.
It's an accessory fuel filter.
I have never seen one before, but the carburetor appears to be the standard NH for a 26-27 with the cowl tank. Maybe that is a sediment bulb just in case the one on the gas tank does not remove all the sediment. Must be aftermarket.
- First Name: Jeff
- Last Name: Humble
- Board Member Since: 2006
I would like to see a picture of the car that goes with those seat cushions.
- Last Name: Maxson
- * REQUIRED* Type and Year of Model Ts owned: 1926 model t coupe
It could be one of those 100 mpg gizmos that were in magazine ads back in the day.
- First Name: Tad
- Last Name: Glahn
Much appreciated gentlemen, I wanted to make sure I had the story straight.
Mr. Humble, I took the photos on the back seat of this ‘16 Maxwell.
- First Name: Jeff
- Last Name: Humble
Wow! What a car.
It's a gas filter - I've had & sold several !
- First Name: Corey
- Last Name: Walker
I always see those on L4 Kingstons, but not very often.
- Attachments
- IMG_4107.jpeg (86.47 KiB) Viewed 2081 times
- First Name: Tad
- Last Name: Glahn
Fantastic! Glad to see one in literature! Thank you Mr. Walker!
- First Name: Bryce
- Last Name: Putnam
- * REQUIRED* Type and Year of Model Ts owned: 1925 C cab 1923 Fordor 1923 Touring 1919 Centerdoor 1915 Speedster
Late '31 Model A Zenith carburetor came from the factory with one similar to that.
Have one of those 'cleaners', got it somewhere among some T parts. It's solid brass, would look nice polished
Guess they do help with dirty gasoline, the fine brass filter screen is rather full of sediment.
- First Name: William
- Last Name: Vanderburg
I have 2 Kingston L 4s and neither one has this.
William L Vanderburg
1922 Center Door Sedan
