1914 touring height
Schweck1914
Last Name: Schwechler
* REQUIRED* Type and Year of Model Ts owned: 1914 touring,1914 speedster
1914 touring height
Post by Schweck1914 » Mon Nov 18, 2024 9:04 am
What is it full height of a 1914 touring, with top up, and nondemountable wheels.....
jpcouture
First Name: Jay
Last Name: Couture
Re: 1914 touring height
Post by jpcouture » Tue Nov 19, 2024 1:34 pm
I have two 1914 touring cars with stock non-demountable wheels and tires. The height on each car is 83 to 83 1/2 inches. My garage door opening height is 82 inches from concrete to the door weatherstrip molding, the cars will NOT fit through the door with the top up. Good luck
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Wed Nov 20, 2024 12:39 am
Jay,
I had an American LaFrance fire engine and the top of the rear rail was about 1" too tall to clear the garage door. However, a "quick release" trim piece around the garage door, attached with a pair of wing nuts, remedied the situation.
Art M
First Name: Art
Last Name: Mirtes
Post by Art M » Wed Nov 20, 2024 10:24 am
When I bought my 23 touring, the garage door was about 1/2 inch too low for the car. I let let the air out of the rear tires. And yes, I did have trouble with a damaged tube stem. At the time, I didn't know the connection of tire slipping on the rim and low tire pressure. In 1977, tire shops were willing to install new stems on tubes. Today I haven't found any shops willing to do so. I could use, instructions on tube stem replacement.
Art Mirtes
NealW
First Name: Neal
Last Name: Willford
Post by NealW » Wed Nov 20, 2024 12:17 pm
The OP's questions was answered, but I seem to recall reading on the forum once that the T's with the "one man top" are not quite as tall as the "one man top" cars. Is that correct?
I do know that the runabouts (at least our old 15) do not sit as tall as the two man top touring cars. Our old house had a 7' high garage door and I could get the runabout in and out without lowering the top. Not so with our 21 or later our 11 touring. I tended to drive the 15 more often because I could just start it and go without having to put the top up or down. Last year we moved to a different house with 8' garage doors and problem solved.
jpcouture
First Name: Jay
Last Name: Couture
Post by jpcouture » Wed Nov 20, 2024 6:06 pm
Thanks Keith for the removable trim idea. The header is 84" so the cars should fit without the trim. We have been considering replacing two trim boards with a piece of aluminum facia trim. The actual door is tall enough so it should not be noticeable from the street. Projects for next summer, flurries are swirling today.
