Gray and Davis Starter
Topic author - Posts: 319
- First Name: Gary
- Last Name: Hagen
Who is using one?
- First Name: craig
- Last Name: leach
Re: Gray and Davis Starter
Hi Gary,
Can I assume you have a hand crank only car & getting it stared is getting to be a issue. I'm working on a combination primer cup/auto reset
compression release setup to make it easier to start a hand crank only car maybe even using a gear reduction assisted cordless drill to use
as a starter. If that is the Grey Davis starter inquiry purpose. send me a email OK.
Craig.
Craig.
