Cast iron warford install problem
Jerry Young
Topic author - Posts: 81
- First Name: Jerry M
- Last Name: Young
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring1927
I have tried searching for my particular problem with the installation of a 920-1 case iron case Warford in a 1914 Touring. Problem is - the center "U" shaped portion of the emergency brake shaft hits the front of the Warford preventing the Ford transmission from going into high gear. Has anyone experienced this problem and how did you fix it? TIA Jerry
Jerry Young
- Last Name: Young
Re: Cast iron warford install problem
Never mind, the Great Henry Lee came through for me, THANKS HENRY!!!!!
Tim Williams
- Last Name: Williams
- * REQUIRED* Type and Year of Model Ts owned: 1925 Model T Speedster, 1922 Model t Speedster project
What was the fix/solution?
Tim
Tim
