Removing engine with a Warford question
Jim11787
First Name: Jim
Last Name: Sarc
Board Member Since: 2023
Post by Jim11787 » Wed Nov 27, 2024 5:34 pm
My first time pulling a model T engine. It’s a 26 Roadster Pickup with an older aluminum Warford installed. I do have a frame brace supporting the Warford. Question-do I unbolt the Warford from the hogs head when hoisting the engine out (my preference) or do you try to take the Warford out bolted on which seems like it would be difficult? Also if leaving it in place does the Warford need to be drained before unbolting from the hogs head?
Last Name: House
Re: Removing engine with a Warford question
Post by George House » Wed Nov 27, 2024 6:00 pm
Unbolt it from the T transmission. Leave it hanging on its support. Won’t need to drain it..
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Wed Nov 27, 2024 7:25 pm
Jim,
I agree with George, leave it in place. You might want to support the front of the Warford a bit, just to prevent bending the support bracket and putting stress on the drive line tube.
Good Luck.
John.Zibell
Last Name: Zibell
Post by John.Zibell » Thu Nov 28, 2024 8:48 am
What Terry and Jim said is how I do mine. Remove from transmission but support the Warford.
1926 Tudor
Jim11787
First Name: Jim
Last Name: Sarc
Post by Jim11787 » Thu Nov 28, 2024 10:06 am
Thanks for the info guys!
