Pickup bed attachment hardware
fordt
First Name: Rob
Last Name: Trippet
* REQUIRED* Type and Year of Model Ts owned: 27 Roadster PU
Post by fordt » Mon Dec 02, 2024 2:15 pm
What is the size and type of these bolts that hold the 26-27 pickup bed to the frame? I’m thinking hex head and fine thread, but size and length? I know they have to pass all the way through the frame and the wood blocks up in the frame…. Thanks!
Re: Pickup bed attachment hardware
Post by Jerry VanOoteghem » Tue Dec 03, 2024 6:32 am
Correct me if I'm wrong, but isn't that a Model A box?
Post by DanTreace » Tue Dec 03, 2024 10:29 am
The bed is correct for a 26-27, here is the parts drawing of the T bed.
The bed fasteners are hex bolts, with washer under, the length don't recall, but the bolt dia. should fit the hole in the bed flange and into the runabout body subframe. The bolts in photo are original fasteners reused.
Rear fender mount to bed.jpg (85.44 KiB) Viewed 1016 times
Post by Jerry VanOoteghem » Tue Dec 03, 2024 12:10 pm
Thanks for setting me straight, Dan. :)
